FUELLESS CAR PROTOTYPE by ISMAEL MOTOR
Started by luishan, September 08, 2010, 11:50:07 PM
e2matrix
Quote from: Mark69 on February 18, 2011, 10:03:46 AM
Yes, please get this information out for everyone into simple, easy to reproduce format so the rest of the world can build it before it is lost or covered up!   ;D
Well unfortunately as bolt has just mentioned Ismael is tied to investors apparently.  I had always heard he was not open to sharing all the technical details.  Unfortunately that may be his failing.  I think if he were to sell kits of controllers and details it would get replicated and become big enough to not be stoppable.  However with the info hartiberlin has posted from Konzen I would guess some very savvy and dedicated person with some money could take the concept given and reproduce it.  Of course that would not be good ethics wise unless they were giving some to Ismael.  Lets just hope that either way it works into being a replacement for the insane way we are currently getting most of the worlds energy.
kmarinas86
Quote from: hartiberlin on February 18, 2011, 10:11:44 AM
It is different, cause Konehead already told us, how it works.
The shorting of coils in this configuration is not new.
Newman has already done this in his earlier models with his
mechanical commutators, but as these were very fragile
and he never explained it well, this knowledge got lost...
Now Konehead and Ismael have reinvented it and gave it a new
spin with using this AC cap in series to block the Lenz law
and Ismael even seems to exponentially extract more energy by
even shorting out the induction spike voltages at the caps,
so he is some kind of step charging his caps from the ringing peak
spikes, so he gets higher and higher voltages at his caps and then after
every pulse is shorting out the coil again with the higher voltage applied
from the cap so the next induction pulse will be even higher and put back more
voltage into the cap bank.
As the energy stored in caps is dependend from the SQUARE of the voltage,
he just really exponetially raises his energy output this way.
He really captures the energy that was lost in Joe Newman´s demonstration to radio frequency
bursts.
Do you still remember when Newman drove his repulsating unit with 10.000 Volts how
much radio frequency energy it put out in the surrounding and how many CFLs he flashed ?
There is really something going on inside coils, when you collapse and
let hit magnetic fields versus each other.
When you ever watched how spinning toy gyroscops crash into each other and what
mechanical energy is released then, you can understand the theory of Joe Newman.
The same is true here and Ismael has suceeded to bring this to the next level
and capture all this energy in his bifilar coils and convert it to
real usable electrical energy.
In my opinion it is just a confirmation of what Jeo Newman has discovered and
there are really tiny gyroscopic particels ( the particels  or waves that are the magnetic
field lines) converted into energy, so we have a very tiny small mass to energy conversion.
But as it is E= m * c^2 it is so powerful.
Regards, Stefan.
I created a playlist on YouTube showcasing the Ismael invention.
On my channel page:
http://www.youtube.com/user/kmarinas86#grid/user/41172E6280825AD2
Just the playlist:
http://www.youtube.com/view_play_list?p=41172E6280825AD2
Also see my elaboration of Newman's theory of Gyroscopic particles:
http://www.overunity.com/index.php?topic=9638.msg257779#msg257779
Qwert
This forum already knows the way to "short" coils to produce spikes, compiled here at Bruce's TPU Theory and Experiments ver.1.2, Reply #561: http://www.overunity.com/index.php?topic=2300.msg221623#msg221623
bolt
Quote from: ramset on February 18, 2011, 08:12:05 PM
Bolt
Yes you have been saying this a long time,So now it seems that Ismael has maximized this effect?
You mentioned "Solid state"? Do you feel what he has done is optimize the old technique with solid state speed and accuracy.
Or is there something extra that he does?
Are you willing to share any ideas here that could assist a replication of your HHO looping  or gen set tech??
Thank you
Chet
RV is a teaching tool everyone needs to start somewhere. Here you learn that RF=RE as a simile where RF techniques are converted to Electrical Power engineering. Eventually it all comes down to RLC and tune tune and more tuning.  Here you will learn the importance of VARS where standing waves and power factor zero equate to an infinite VSWR. Within the TPU its a triple frequency stacked co-linear 3 phase solid state RV tuned to create infinite VSWR or PF zero or standing wave condition of immense VARS. This creates a partial singularity device which creates compressed gravity due to the singularity and time compression. For a 1000 watt device the VARS within the device will be around 10KVAR's
You also notice that the "gurus" of our history all most always start with looped motor/generator systems then later it becomes a solid state design. Kapanadze is a fine example of this. If you have a generator where a moving magnet or coil is just replaced with a stationary magnet and coil except now you just pulse it.  Then you find a way to extract the pulse without lugging. Several methods can be used  such as switching the pulse into a load cap then disconnecting the source. Or using bifilar windings to prevent self induced magnetic fields. This is kapandaze trick. Or short on coil pulse peaks creates harmonics of much higher frequency and of greater energy then the source pulse. By using a simple high pass filter you can literally syhon off the HF energy without disturbing the LF source frequency provides an anti-lugging generator. Magnacoaster technology works exactly the same except is using Bloch Wall modulation on carrier frequency and the excess harmonics are pulled off using High pass filter. Other methods include switching flux paths and isolating the source after pulsing creates excess energy from ferromagnetic resonance of the iron goes OU. This produces a MEG transformer typical COP is around 3.  Several people have done this from Bulgaria, Russians, Italians many people made this flux path switching MEGs and shown i/p about 1kw and providing about 3Kw o/p.
So here is the summary - there is nothing new under the sun its all basically what we already know but the tweaks are in the details. There is no need to work BLIND first accept that OU is real that takes most people about 10 years for the brain to activate. Then research the many methods and start building upon the things you know starting very small and make it bigger this is how Ismael made his electric car.
neptune
@bolt . Your last post was quite informative .However much of the information was of a general nature , rather than specific . The problem for most people is that there is loads of information about , some of it true , and some of it misinformation . It is like having a textbook where someone has torn out  the first 100 pages . We need to start at page one . The nearest I have seen to this was Bedini and the Simple Schoolgirl device . Sadly , as far as I know , no one could make it work in a proven OU manner . I would love to see Bedinis electricity bill . Theory on its own is just theory . The world still awaits a simple apparatus that demonstrates OU . I don't want this post to be offensive , but we get claim after claim , and it always seem to come to nothing .We can only continue to hope .
