FUELLESS CAR PROTOTYPE by ISMAEL MOTOR
Started by luishan, September 08, 2010, 11:50:07 PM
konehead
hi Qwert
Ovi Fetche in Romainia has a coil-shorting circuit that he uses in a motorcycle ignition system and it works great he says:
Qwert
Hi, konehead.
My intention of showing this feature (collapsing current to reinforce power) is to make you aware that it was known and used for long time.
kEhYo77
I finally got my coil shorting going! :D
I had to rebuild my PWM driver as the old one has gone in smoke :)
I've dug up my old setup with a rotor and I am driving it GAP POWER style magnets all same pole out.
Driving coil in attraction polarity magnets behind the coil in repelling mode to the rotor.
I am shorting two gen coils non stop, they're hooked up in parallel.
I'll make a short video soon.
kEhYo
konehead
Hi Kehyo
Looks really fun - try pulsing those coils you have, then shorting them right after the motor-pulse has turned off, keeping everything (both motor coisl pulse and motor coil short) "within' the sinewave peak period that the rotormagnets create........or just use them as gernator coils, see if you cna get draw to "prime mover"  be not affected at all...use RPM meter to check draw as you dont want it to slow even 1 RPM to be dead-sure....ammeters can/will show no extra draw, but there may be some rpm drop.....so RPM meters are best to make ssure there is no reflection with the ringing into caps, and also the caps into load - neither should affect rpms or draw at all...if you dont have a two-stage diode-plug type circuit where cap disconnects from coils when they hit load, you will get a reflection in extra draw unless you hit on something really unique...(like Thane or RomeroUK getting speed up under load)
Hi Qwert
yes besides igniton-coil type circuits, Tesla's spark-gap stuff is almost exaclty like a "coil short at peak" since the spark gap jumps only at the high voltage peak (so it happens at peak period) and the spark-jump, when it reaches other side, will SHORT the coil that caused the jump to happen in first place....
also Joe Newman I heard used the coil-shorting to happen right at the time the motor-pulse turns off like just described to kehyo...
but, I have never heard before of people shorting GENERATOR COILS  into caps, and the from caps into load  in two-stage output tyep of thing so gernator doesnt affect draw to motor spinning it...this is sort of new territory and is key to lenz-less generators of any mechanical design..
Ismael has taken the whole coil-shrting thing to high level, with HF resonate pulsing and shorting the "peaks of the rings" is something I dont beleive has been done before excepy maybe by Tesla wiht some variable-capacity caps and crazy spark gap resonance stuff and it probalby was extremely fickle to sustain over a long time.
apparently Edwin Gray used very large capacitors that "imitate" a short-circuit from their resistance and he would hit 5 or so quick pulses into these - not quite same thing as coil short at peak but similar....
Qwert
Quote from: konehead on July 01, 2012, 01:40:43 PM
You are right, konehead. There was however a lot of discussion on this subject several years ago on threads related to TPU (Toroidal Power Unit) at this forum. A treasure of info, only problem to dig it up.
