Thanks to ALL for your help!!
Waldens inertial drive is an optical illusion
Started by CuriousChris, September 10, 2010, 05:57:32 AM
FredWalter
Quote from: CuriousChris on March 31, 2011, 05:19:16 AM
Please feel free to "do the math" and prove me wrong.
I've attached a simulation that I did using Maple.
Here is the Maple code:
---attempt01.txt
restart:
with(plots):
setoptions(scaling=constrained):
printf("For the mass track, use a 2-dimensional circle, centered at the origin (0, 0), with radius='RADIUS'.\n");
printf("Let the mass arm be rotating at 'RPM' rotations per minute.\n");
printf("Put the center of rotation of the mass arms at (0, OFFSET).\n");
printf("Put one end of the rotating arm at point P on the circle.\n");
printf("Let 'L'=the length from (0, OFFSET) to P.\n");
printf("Let 'A' be the angle between lines (0, 0) to (0, OFFSET), and (0, OFFSET) to P.\n\n");
printf("Using the Law of Cosines for the triangle formed by the above points, we get the following equation:\n");
printf("\tRADIUS*RADIUS = OFFSET*OFFSET+L*L-2*OFFSET*L*cos(A)\n");
EQN01 := RADIUS*RADIUS = OFFSET*OFFSET+L*L-2*OFFSET*L*cos(A):
ANS_EQN01 := solve(EQN01, L):
L := A -> OFFSET*cos(A) + sqrt(RADIUS*RADIUS+OFFSET*OFFSET*(cos(A)*cos(A)-1)):
printf("Solving '%a' for 'L' gives us:\n\tL(A)=%a\nand\n\tL(A)=%a\n\n", EQN01, ANS_EQN01[1], ANS_EQN01[2]);
printf("Let us use the first solution for L:\n\tL(%a)=%a\n\n", A, L(A));
Px_A := A -> L(A)*sin(A):
Py_A := A -> OFFSET-L(A)*cos(A):
printf("Using the relationship between the sides of our triangle, and angle A, we get the position of point P as a function of angle A:\n\tPx_A(A)=%a\n\tPy_A(A)=%a\n\n", Px_A(A), Py_A(A));
A := t -> t*(2*Pi)/RPM:
Px := t -> simplify(Px_A(A(t))):
Py := t -> simplify(Py_A(A(t))):
Vx := t -> simplify(diff(Px(t), t)):
Vy := t -> simplify(diff(Py(t), t)):
Ax := t -> simplify(diff(Vx(t), t)):
Ay := t -> simplify(diff(Vy(t), t)):
Sx := t -> simplify(diff(Ax(t), t)):
Sy := t -> simplify(diff(Ay(t), t)):
printf("Angle A is a function of time:\n\tA(t)=%a\n\n", A(t));
printf("Position of point P as a function of time:\n\tPx(t)=%a\n\tPy(t)=%a\n\n", Px(t), Py(t));
printf("Velocity vector at of point P as a function of time:\n\tVx(t)=%a\n\tVy(t)=%a\n\n", Vx(t), Vy(t));
printf("Acceleration vector at of point P as a function of time:\n\tAx(t)=%a\n\tAy(t)=%a\n\n", Ax(t), Ay(t));
printf("Surge vector at of point P as a function of time:\n\tSx(t)=%a\n\tSy(t)=%a\n\n", Sx(t), Sy(t));
RADIUS := 5: # 10" diameter mass track
OFFSET := RADIUS/2: # arbitrary
RPM := 1:
Alpha := 0: # do one full pass around the mass track
Omega := 1:
Curve := plot([Px(t), Py(t), t=Alpha..Omega], style=line, color=blue, thickness=2):
NumFrames := 30:
t := i -> Alpha + i*(Omega-Alpha)/NumFrames:
VScale := 0.1: # arbitrary
AScale := 0.01: # arbitrary
SScale := 0.001: # arbitrary
Points := display(seq(pointplot([Px(t(i)), Py(t(i))], style=point, symbol=circle, symbolsize=17, color=black), i=0..NumFrames), insequence=true):
VVectors := display(seq(arrow([Px(t(i)), Py(t(i))], VScale*<eval(Vx(a), a=t(i)), eval(Vy(a), a=t(i))>, width=.02, color=red), i=0..NumFrames), insequence=true):
AVectors := display(seq(arrow([Px(t(i)), Py(t(i))], AScale*<eval(Ax(a), a=t(i)), eval(Ay(a), a=t(i))>, width=.02, color=red), i=0..NumFrames), insequence=true):
SVectors := display(seq(arrow([Px(t(i)), Py(t(i))], SScale*<eval(Sx(a), a=t(i)), eval(Sy(a), a=t(i))>, width=.02, color=red), i=0..NumFrames), insequence=true):
printf("Here are some graphs following the point P for one full revolution of the mass arm, using the following values:\n\tRADIUS=%f\n\rOFFSET=%f\n\tRPM=%f\n\n", RADIUS, OFFSET, RPM);
display(Curve, Points, title="Mass Path");
display(Curve, VVectors, AVectors, title="Velocity+Acceleration");
display(Curve, AVectors, SVectors, title="Acceleration+Surge");
CuriousChris
Thats really cool.
I wonder if I can use that tool to test my own theory.
One thing though. As far as I can tell. and this may be just because I have never read a maple script before and may be relying too much on the images but are you modeling just one mass. Is that correct?
The image that shows the mass motion (mass_path.gif) only displays one and the vectors in the other gifs only show one. Waldens patent relies on multiples of two masses. its the summation of these forces I contend equals a vector force of 0.
CC
FredWalter
Quote from: CuriousChris on March 31, 2011, 09:05:22 AM
If you can represent everything in your theory using equations then you probably can use Maple to help test your theory.
Yes. I did this last year sometime, and haven't had time to extend it to cover two masses.
You can integrate the force equation over the circle for one mass.
If F=M*V*V/R (as I've found in some text books) then you get a non-zero result.
If F=MA then you get 0.
When I look at the values of A and V as the mass moves over one revolution of the mass track, A=V*V/R only when V is tangential to the mass track (IE. for my setup, when x = 0).
It looks to me that F=MA is the general equation for force, and F=M*V*V/R is the equation that applies only when the velocity vector is tangential to the curve upon which the mass is moving.
I still haven't found a derivation of F=M*V*V/R, and until I find a derviation that shows it is always valid, I'm going to have to wonder if it valid to apply it to the WIP device.
Here is the maple code that I used to get these results (append it to the maple code in attempt01.txt):
Amagnitude := t -> sqrt(eval(Ax(a), a=t)^2+eval(Ay(a), a=t)^2):
Vmagnitude := t -> sqrt(eval(Vx(a), a=t)^2+eval(Vy(a), a=t)^2):
printf("\n");
for i from 0 by 0.05 to 1 do
printf("Time=%f Amagnitude=%f Vmagnitude^2/RADIUS=%f\n",
i, evalf(Amagnitude(i)), evalf(Vmagnitude(i)^2/RADIUS));
end do;
printf("\n");
FAx := t -> simplify(eval(MASS*Ax(a), a=t)):
FAy := t -> simplify(eval(MASS*Ay(a), a=t)):
FAmagnitude := t -> simplify(sqrt(eval(FAx(a), a=t)^2+eval(FAy(a), a=t)^2)):
Total_FAx := simplify(int(FAx(t), t=0..1)):
Total_FAy := simplify(int(FAy(t), t=0..1)):
Total_FAmagnitude := simplify(sqrt(Total_FAx^2+Total_FAy^2)):
FVx := t -> simplify(eval(MASS*Vx(a)^2/RADIUS, a=t)):
FVy := t -> simplify(eval(MASS*Vy(a)^2/RADIUS, a=t)):
FVmagnitude := t -> simplify(sqrt(eval(FVx(a), a=t)^2+eval(FVy(a), a=t)^2)):
Total_FVx := simplify(int(FVx(t), t=0..1)):
Total_FVy := simplify(int(FVy(t), t=0..1)):
Total_FVmagnitude := simplify(sqrt(Total_FVx^2+Total_FVy^2)):
printf("integrate F=MA over one revolution and you get: %a\n",
evalf(Total_FAmagnitude));
printf("integrate F=MV^2/R over one revolution and you get: %a\n",
evalf(Total_FVmagnitude));
Here is the output from the above Maple code:
Time=0.000000 Amagnitude=444.132198 Vmagnitude^2/RADIUS=444.132198
Time=0.050000 Amagnitude=433.781166 Vmagnitude^2/RADIUS=433.132245
Time=0.100000 Amagnitude=402.908288 Vmagnitude^2/RADIUS=399.815957
Time=0.150000 Amagnitude=353.424767 Vmagnitude^2/RADIUS=344.643860
Time=0.200000 Amagnitude=291.761146 Vmagnitude^2/RADIUS=272.820308
Time=0.250000 Amagnitude=227.928750 Vmagnitude^2/RADIUS=197.392088
Time=0.300000 Amagnitude=169.374817 Vmagnitude^2/RADIUS=134.142398
Time=0.350000 Amagnitude=119.976251 Vmagnitude^2/RADIUS=90.909984
Time=0.400000 Amagnitude=82.432846 Vmagnitude^2/RADIUS=65.672556
Time=0.450000 Amagnitude=58.162465 Vmagnitude^2/RADIUS=53.106629
Time=0.500000 Amagnitude=49.348022 Vmagnitude^2/RADIUS=49.348022
Time=0.550000 Amagnitude=58.162465 Vmagnitude^2/RADIUS=53.106628
Time=0.600000 Amagnitude=82.432846 Vmagnitude^2/RADIUS=65.672556
Time=0.650000 Amagnitude=119.976251 Vmagnitude^2/RADIUS=90.909985
Time=0.700000 Amagnitude=169.374817 Vmagnitude^2/RADIUS=134.142398
Time=0.750000 Amagnitude=227.928750 Vmagnitude^2/RADIUS=197.392088
Time=0.800000 Amagnitude=291.761146 Vmagnitude^2/RADIUS=272.820308
Time=0.850000 Amagnitude=353.424766 Vmagnitude^2/RADIUS=344.643860
Time=0.900000 Amagnitude=402.908288 Vmagnitude^2/RADIUS=399.815957
Time=0.950000 Amagnitude=433.781166 Vmagnitude^2/RADIUS=433.132245
Time=1.000000 Amagnitude=444.132198 Vmagnitude^2/RADIUS=444.132198
integrate F=MA over one revolution and you get: 0.
integrate F=MV^2/R over one revolution and you get: 158.5148465*csgn(MASS)*MASS
