BWJT
Started by kooler, September 11, 2010, 11:25:22 AM
kooler
figure i would post some schematics of the backwards joule thief..
conradelektro
Thank you Kooler!
Great, I will make some test and measurements with your backward Joule Thief.
Could you please give an indication of the capacitor value and the tune-able resistor value you recommend?
In the circuit on the right (the one with the air core):
- I would put at least 40 turns on a 50 mm (2" inch) air core to come close to 100µH?
- And according to your teaching, there should be a third inductance between the collector (of the transistor) and the + pole (of the battery)?
I guess the three circuits are all for very low voltage batteries (0,5 Volt and even 0,25 Volt)?
Greetings, Conrad
conradelektro
Hi Robbie (Kooler)!
Because I am thinking about implementing your BJT and because I like air core coils, further questions concerning the circuit on the right side (the one with the air core):
The two windings 30 turns and 20 turns (air core), are they
- on two separate cores (two independent coils),
- bifilar,
- two windings one after the other on a single air core,
- wound (connected) in an counter-wound fashion?
Greetings, Conrad
kooler
the below pic is the same as above.. (i fix the diagram above also..)
it has 104k cap 100,000pf= 0.1 uf
10k resistor
mpsa06 transistor        amp draw = 7.8ma's at 0.9 volts
kooler
sorry but i fix the aircoil bjt .. this time it is right..
