My free energy experiment.
Started by stevensrd1, September 12, 2010, 11:07:25 AM
stevensrd1
New update,,as of 7:00 am,,5 recharging bats reading 1370,,motors still spinning without slowing,,thinks this will turn out well. More later..
stevensrd1
Update,,recharging bats reading 1375,,experiment continues..
stevensrd1
I can notice the motor slowing some now,,recharging bats still at 1375,,so im sure I will get to the final test today,,sometime. Then the final results will be posted,,but it still spins on fairly fast now,,but I can notice some speed loss..Ill post the main drain motor test and amp test when it stops..Doubt the readings will go up much more,,but if it does more then a few points Ill post that as well.
stevensrd1
Ok I went ahead and stopped the test early cause I was just curious what the results were. Im sure it could have ran several more hours if not even into the night had I let it continue. So I did the main drain motor test on one of the recharged AA batteries and got 9 minutes run time,,so thats very good, it held amperage and it takes a whole lot to run that big motor. If you haven't read the previous post, the main drain motor is a motor I use that can drain a AA battery in ten minutes or so which was fully recharged on my AC plug in recharger. I also did an amp test, on DCA on two different settings on one of the recharged AA batteries, heres the results, on the 20m setting for the amp test it read 2.26 and for the 200m setting it read 22.6, so all in all I think this design is a fairly nice one as the test turned out well. I will make a schematic later and post it,,but if you been reading its all already in the post..So thats it for now,,Im sure I will think of something else to try and if it works well post it on here in time.
magnetmotorman
Sorry, but this is not a "magnet" motor, it's a free energy device.
This post should be relocated.
The key is simplicity.
