My free energy experiment.
Started by stevensrd1, September 12, 2010, 11:07:25 AM
shylo
Hi Steve ...I started with 4 bats .....#1-1.36v....#2-1.36v..#3-1.26v...#4-.83v...1&2 in series..+ to cd motor...other motor terminal to + on 3&4...-of 3&4 to - of 1&2....ran for 15 hours...#1-1.28v..#2-1.29v....#3-1.37v...#4-1.35v......I'm going to drain 2 of the bats and redo the exp. ...this time with better connections....just used wire and masking tape 1st time.......but there is definately a recharge taking place while running the motor......next time I'm going to try 3 in parrallel....I'll let you know the results......am looking forward to your next design.........thanx .....shylo
FreeEnergy
why batteries/caps or whatever when you could dump direct wireless electricity from the Tesla Tower to his electric car?
Tesla electric car had batteries and antenna(s) is what i remember reading about. maybe there is more details i missed.
how he did it was not clear enough for replications.
i think he was actually trying to show his works and his technology was filtered out from the public. you all know about his lab being burnt down, but he kept going and released many great inventions/discoveries!
stevensrd1
Yes shylo its a very interesting experiment, and fun to play around with no doubt.
stevensrd1
I thought Id add a bit more to think about with this experiment. As of last night when my recent post ended on my last experiment. I swapped the batteries. I took the main two series batteries that had drained and swapped them with two of the parallel recharged batteries.  Of course this still left one of the original recharged parallel batteries in place since there was three of them that recharged. If you remember or you can read back some. The experiment ended at 9:45 pm with the three parallel batteries recharged at 1350. So like I said I swapped two of the recharged batteries with the two drained series batteries. Just to continue the test a bit further. So this test started at 10:26 pm, with a reading on the parallel bats of 1300, this reading was taken after first start up of the motor. Ill post some of the reading from then to now. 10:26 pm at 1300,,10:32 at 1305,,12:44 pm at 1324,,2:43 am at 1333,,5:14 am 1341,,8:56 am at 1352,,and 9:58 am at 1353,,So thats for the three recharging in parallel,,just thought I would mention that,,kind of interesting I think.
stevensrd1
Another update,,I have noticed the motor a bit slower already. And at 11:39 am Im reading on my recharging bats 1351 now and it was two points higher earlier, before the motor slowed a little. Im thinking Im not going to get much higher, here and the reason is because I have more resistance on the parallel side. Remember in the last post I said I swapped the main dead bats with two of the three recharged parallel bats. However that left one recharged bat on the parallel side, and I think this is causing the resistance and limiting the recharge to more. It has equaled unity if not a point or so over on the meter. But with the one recharged bat that was left on the parallel side,,Im not going to get as long of a motor run then I had the first time. What I should have done was replace that one recharged bat left on the parallel side with a fully drained one and then redid the experiment. I would have had a full motor run like I had the first time then Ill assume,,and no doubt got more of a recharge. The motor is still spinning fairly fast now,,but like I said I noticed some slower spin,,and two points dropped. So I think this relates to all I said above here..Its still unity,,or maybe over,,or at least very close. I enjoyed the experiment,,I may have to repeat it even,,and follow my advice above lol..Which I may or may not post,,as I get lost in many other things, we will see..
