Aether power converter / Virtual photon power converter
Started by core, October 10, 2010, 05:10:39 PM
dllabarre
Anyone
When winding these Kapanadze type coils when is it better to use solid wire?
Or should I always use stranded wire?
Thank you,
DonL
stvnjsha
DC electric fields may be causing the headache.  Fortunately, they can be shielded against (unlike magnetic).  Also, because their strength is inversely proportional to distance, moving away would definintely have an effect.
In addition with strong DC electric fields, the D'arsval (sp?) movement of the analog meter (and any metal around the device), being conductors, may be another example of a conductor being electrically polarized through induction.
Thanks Core
peace
stvnjsha
core
Quote from: stvnjsha on October 20, 2010, 11:36:08 PM
Thanks Core
peace
stvnjsha
stvnjsha,
I think you hit the nail on the head with the DC voltage. As soon as I step away the headaches stop as fast as they started.
I came across some round soft steel rod. I have some glass tubes I will cut to size, these tubes will slide over the steel perfectly. From there I will build two emitter plates to place on the glass tubes. The exposed part of the copper emitter will be covered in rubber. The steel will be bent in a horseshoe fashion.
The big key with high voltage, as I am learning, is bleed through. With my last test using rubber (1/8" thick) between the emitter and the steel road did nothing to stop the high voltage. Using glass should prevent this. Hopefully this week I will get some time to build this.
Also and welcome aboard!  :) There are a lot of people here that can learn from your knowledge. Thanks for the great web site.
Respectfully,
Core
stvnjsha
The bleed through may be due to dielectric leakage.  There is no such thing as a 'perfect insulator'.
Thanks Core.  And, I better introduce myself.
My name is Steven Joshua and it was from my website â€" i-am-a-i.org -- that Core got some of his ideas.  The primary intention of this communication is ‘to get the word out’.  (The I AM A I website itself is a spiritual/mystical how-to website and is presented as a ‘public service’ with no advertisements.)
My electronics background is an A.S. in analog electronics.  After college, I spent five years troubleshooting and repair of analog electronics on the component level â€" TV repairman amongst other things.  It was in college (both in electronics and physics) that I learned about the enigma around Coulomb's Law (http://www.i-am-a-i.org/free-energy/index.html).
Concerning the devices
The devices found in the “Science Geek” entries of i-am-a-i.org are attempts to work with some of this enigma.
•   The electric field transformer (http://www.i-am-a-i.org/free-energy/index.html) is an attempt to produce strong electric fields without arcing issues.  Thereby, making more accessible the physical forces present in Coulomb's Law.  It attempts this through a bi-polar electric field induction (using a very high voltage) into an electrically conductive core -- a closed system.  In an AC condition, the polar charge migration and the accumulation process at the core ‘poles’ is augmented by expanding and contracting magnetic fields.
•   Concerning the virtual photon power converter (http://www.i-am-a-i.org/free-energy/powerconverter.html), the short version is this device is an attempt to convert RF power to real power.  The long version is to use capacitor plates of an electric field circuit as conductors between two transformer windings that are excited through a separate magnetic field circuit.  The two fields mix in one of the transformer windings such that the current energizing that winding is coming into the coil from a high voltage source.
Both of these ideas are working off of the same concept, which is to excite (using magnetic and electric fields from separate sources) a closed conductive electrical system in such a way that the system begins to exhibit intrinsic characteristics of its own.
The idea of electrically exciting a closed electric circuit to get intrinsic characteristics is not new when it comes to coils and capacitors.  For example, a length of conductor x feet long has intrinsic electric and magnetic characteristics.  Put that wire in a coil and the wire now (due to magnetic fields) has different characteristics; specially, when an AC frequency is involved.
Another example is attach a capacitor across that coil â€" create a tank circuit -- and that combination exhibits intrinsic characteristics at a very specific frequency (due to electric and magnetic fields); this is a tuned circuit.
The closed systems involved with these devices here are:
•   In the transformer, the closed system is the conductive core, its shape, and the crystalline matrix that the core atoms are in.
•   The closed conductive system in the converter is the two transformer windings connected through the capacitors plates (the subsequent material matrices of their components and the transformer core material).  Also, there may be spatial considerations.
•   Core appears to be experimenting and may be taking this concept in another direction.
The point is; once some of the concepts that are being presented is understood, there is a multitude of directions to go.  Because the application of some of these ideas may even open up new fields, conceivably lifetimes of study may be involved.
When in college (in both in world history and the history of electronics), I learned an innovation occurs, is adapted, and then over time its use becomes crystallized â€" stuck in a rut; then, another innovation occurs, etc.
This crystallization process has happened in the exploration of other electric and magnetic field applications.  A major variable in this current crystallization formation is the perception of return â€" what ‘pays’.
This communication is a call to “start thinking out of the box”.  What the above devices have in common is taking the old concept of field excitation of a closed conductive circuit â€" a closed system -- into other directions.
The beginning of this communication stated the primary intent is to get the ideas out there.  The more people playing with these ideas (or the concepts behind the ideas), the better.
Myself, I am a religious. I’m more into/in God and don’t have the requisite passion or resources.
Sooo…this communication will end like this:
MAD SCIENTISTS NEEDED
The must want to play with the above concepts or their equivalent in their basement or garage.
(You too can amaze your friends, impress your neighbors, excite your lover, win a Nobel Prize, or maybe save a planet or three.)
  ;D
Thanks again Core
The Peace of God is with you; it never left.
stvnjsha
e2matrix
stvnjsha,  Thanks for posting here.  You've got a very nice web site which I enjoy all aspects of including the spiritual.  Cheers
