Relative Permittivity of Water
Started by Torana, October 14, 2010, 04:35:01 AM
Torana
w,
theres a book  *-Timer/generator circuits manual-  by R Marston *
it covers 555 to xr2206 , LC , xtal ,pLL ,sine , square , triangle  ,saw and wave shaping. its a good book too ,read it a few times over the years . its available thru local library thru -inter loan*-...
there IS a charge.
Torana
R,
the hydro is a pretty good example , the least amount of i.p = higher eff.
the environment takes up the diff.    turbines DONT turn on their own do they?
MasterPlaster
Mr T
Your knowledge could save people who are not able to help themselves so please tell us what you know.
This may make you think:
http://amazonwatch.org/work/belo-monte-dam
Torana
POWER SUPPLIES ONLY** I dont recommend building or buying. Its YOUR MONEY!
Ive built similar in the past.
heres links to PS which are mobile. ALL using push pull. Enough info to get an understanding.
this is origin of on board PS = valve radio in the 40s using vibrator 50 - 100hz centre tap trans
Questions ask =cablehack**
http://cool386.tripod.com/tradio/tradio.htm vib= grey can v5124
kenwood stereo TL494 chip . Questions ask =Risto**
http://elkomak.4t.com/catalog.html
John clarke silicon chip cdi using IR2155
http://www.molla.org/DIY-CDI/SC-DIY-CDI-article-hires.pdf
John clarke silicon chip 2KW inverter DATE NOV 1992 .  TL494 chip
http://www.siliconchip.com.au/cms/archiveindex.html
#109 PS and TUTORIAL TL494 chip Questions ask = perry babin**
http://www.bcae1.com
Jaycar info
http://www.jaycar.co.nz/images_uploaded/dcdcconv.pdf
http://www.jaycar.co.nz/primers.asp
open an old computer and no doubt theres TL494,TL594,KA7500,SG3525  these chips have 2 OR 1 output option for 1 or 2 transistors
basically these circs are all the same but diff power rates suited to requirements.
I still use 555 now and then , theres nothing wrong with them.**These circs are for those that want an independent PS.
Torana
stephen horvath patent has a push pull circ but drawn its inoperable. this is the correct hook up where the core itself triggers the 3055 base pins=self oscillating transformer.
sec Z is reflected back to pri otherwise itd burn
