Relative Permittivity of Water
Started by Torana, October 14, 2010, 04:35:01 AM
canufi
Quote from: Torana on September 01, 2011, 09:23:30 PM
A choke with a wiper arm is mythical other than an air core crystal radio set ,which is normal.
Theres screw slug cores or on a large scale , Ferranti style moving coils.
**Its a Unicorn coil = BOGUS!
You think a variable inductor is bogus? Really?
Quote from wikipedia:
"A variable inductor can be constructed by making one of the terminals of the device a sliding spring contact that can move along the surface of the coil, increasing or decreasing the number of turns of the coil included in the circuit. An alternative construction method is to use a moveable magnetic core, which can be slid in or out of the coil. Moving the core farther into the coil increases the permeability, increasing the inductance. Many inductors used in radio applications (usually less than 100 MHz) use adjustable cores in order to tune such inductors to their desired value, since manufacturing processes have certain tolerances (inaccuracy).  "
Torana
Good one!  the jimmy choo overunity hand bag forum.
1 ; Define successful ;  ...its normal to produce gas with DC.
8XA circuit is 30 years old , read the date on it. thats before youtube or ou.com
1981 people have been copying that crap.
If a walmart kettle is 99% eff then what is a water R eff ?
post #25 = read it!
Stans "circuits" are for entertainment value only. No one is rushing to replicate Puharich , his circuit is unreleased.  No one is claiming replication of Horvath , Ive linked his "circuit " + components on this thread. I also pointed out components are backwards, short and inoperable.
This is std practice for patent office drafting = the actual people who bring you Patents
Ive pointed out SCR is a thyristor = AC phase controller...it still doesnt hit home, not even as it is an AC device.
Do people beleive stan left a circuit for them ?  YES!!!
the Truth and Fact cant even open their minds,  therefore their free thinking is limited by their imagination.
NO where have I tried to discourage anyone or put down any ones efforts, its a personal choice. Ive put links everywhere so people can sharpen up.
Torana
2:  when did I say " a variable L is BOGUS" ???
sep 2 2011 = everything I wrote falls in line with the wikipedia quote.
Have replicators used a slide coil with HV??
Does HV arc between 2 close proximity conductors ?
Read further in the thread =post #122 and quote 1st sentence, sep 20 2011....carefully!
post #4 I used one word that I knew would trigger the inner Teacher Gene =  "STUDENT"
sure enough it do!
Torana
Whoops!    1981 = 31 years ago .  quite a few people have walked that path before the internet generation.
Your calling everyone to work on motor gen sets , wouldnt it be more constructive if you yourself stepped up ?
some practical experience under your belt will either push you forward or stop you in your tracks
George Wisemans welder info has been available for  20 years.
**anyone who has worked with gas will know that the ign advance needs*reworking*  ,not in theory but in Practice!...it means getting hands dirty.....and it takes mathematics too!
Briggs and Stratton manuals are in libraries all over the world = a good place to start if you are at the starting line
good luck motivating yourself.
canufi
Quote from: Torana on June 02, 2012, 09:45:32 PM
Please look up Tony Woodside and Gary Woodside and Irondmax on youtube who have successfully replicated the distilled water and tap water cells which break apart water with the 9XB and 8XA circuits.
Irondmax is not dishonest he has videos pouring actual walmart distilled water into his cell.  Look up irondmax videos please.
He also has videos of the steam resonator working.
I'm not disputing whether Stan's devices worked, they definitely functioned.
However I am disputing whether Stan's devices took energy from "Radiant energy" or "kinetic molecular energy".
If stan's devices work, which they do, that is still not evidence that they are over unity, nor is it evidence that they are taking energy from the Sun, which was what Stan claimed in his later lectures.
Most idiots on youtube have not built any of the circuits and are just building cells and pipes instead of focusing on the circuits. IronDmax and Tony/Gary Woodside have built the circuits and coils and they match up exactly similar to Stan's actual devices in his estate. You do realize that his estate has been closely photographed and Tony Woodside has videos of Stan's actual cell functioning at the estate? You do realize that someone visited Stan's estate and actually tried the cell independently recently, which Tony/Gary Woodside has videos of? You do realize that the water fuel cell was actually tested recently, the original Stan Meyer cell built by stan himself?
Have a look at:
http://www.youtube.com/watch?v=txjRpXe8JwA
http://www.youtube.com/watch?v=5tGmrPggs7w
http://www.youtube.com/watch?v=xq4WDb3iPvg
