Alternator with wheel
Started by guruji, October 18, 2010, 04:05:56 PM
guruji
Hi guys I've been trying for along time to turn a small wheel on an auto alternator using magnets around and a coil with a reed switch as a pulse motor but invain.Maybe magnets should be bigger.
Any suggestions?
Thanks
geotron
What would benefit you is research into the Gray Conversion
Tube.  The way it works is by filling an insulated tube with
high voltage from a thick copper electrode pointed at another
shorter electrode.  This shorter one is positioned with a small
gap to the other, and is connected to a diode to block the flow
of high voltage from going past it.
When the diode is activated with a low voltage, the high voltage
presses against the flow and shuts the diode off.  When this
occurs, a burst of radiant energy forms in the gap between the
electrodes and is collected onto a waiting copper mesh tube or
other suitable conductor.
This collected radiant energy can then be directed into a pulse
type motor setup and then fed back to the supply battery. It will
produce a substantial magnetic flux event in comparison with a
normal pulse of electricity.
You will find a load of information on the Gray System in this
forum and the one at Energetic Forums.
nievesoliveras
I took an alternator and changed the rotor for a permanent magnet one. I also tried to run it using magnets and a pulsing coil. I could not move it even once.
Now I am trying to make it work with a microcontroller. But every device I buy to deal with the microcontroller programming has come incomplete. There is the need to buy something else to make the thing complete.
The thing is that I have spent a lot of money and still has not moved the alternator using a microcontroller.
The circuit to move the alternator is already made and maybe you know how to make it work with a microcontroller. It may help you if you have the microcontroller know how. The circuit link:
http://www.overunity.com/index.php?topic=9596.msg256831#msg256831
Jesus
guruji
Hi guys thanks for your interest. I think it should have big magnets to have more torque. I saw a guy on youtube who managed to turn an alternator not a car one but this had big magnets in it.
Maybe the window motor should be put on it which have good torque.
Hope I solve this in future;still expermenting on it.
Thanks
shylo
Hey.....I don't think increasing magnetic strenght will help....I believe that the resistance from gravity will always match the strength of the magnet..........magnetism and gravity are =?...........shylo
