Thanks to ALL for your help!!
Captret - Capacitor and Electret
Started by ibpointless2, October 19, 2010, 06:49:51 PM
nievesoliveras
Tito L. Oracion
gravityblock
@Groundloop,
Is there a quick circuit you can design and test, so we can see if this effect is useable or not.  You mentioned the captret charges more when you let it rest, so I assume it won't accumulate a charge quick enough in order to keep a LED continously lit.  Even if the LED can flash every few minutes without an external charge would be OU and would be cool.  I have a feeling after so many flashes, it won't light up due to hystersis and will need an external charge.  I hope I am wrong on this.
Thanks,
GB
Groundloop
@gravityblock,
It seems that this effect is much like the memory effect in rechargeable batteries.
If you drain a lead acid battery fully it will still have a small voltage. It will take
a very long time (shorted out) to remove that voltage. I was thinking of making a small
ocillator to boost the voltage to drive one ultra bright LED. But I need at least 1,3 volt
and approx. 1mA to do that. One capacitor will provide 0,1 volt @ some few pico Ampere.
So I will need A LOT of capacitors in series and parallel. Can't promise anything but if I
find a way to do it then I will post it here.
Groundloop.
