Captret - Capacitor and Electret
Started by ibpointless2, October 19, 2010, 06:49:51 PM
hartiberlin
Here is an interesting analysis from Dr. Stiffler.
he also warns about that the caps could be exploding:
http://67.76.235.52/capret.htm
By the way, did Dr. Stiffler remove all his Youtube Videos
from his
mrh2o2
youtube account ?
I don´t find it anymore.
altrez
Quote from: hartiberlin on January 21, 2011, 12:29:38 PM
from his
mrh2o2
youtube account ?
I did see that on Dr. Stiffler's site and it makes sense, as in the caps are building up pressure inside when you apply too much current.
Indeed his videos are down?
-Altrez
NickZ
   All:
   Holy cow!!! Thanks for the link, Stefan.   Stiffler is very right...
Great experiments. I also would have to agree with his findings, But, there is still some magic to the Captret- Ringer  that he may not have as yet discovered...  How to upgrade the effect without blowing the caps.  Why bother?  Because the caps are drawing energy from the surrounding space, and converting it into usable electric power. And that in itself needs to be studied, and utilized.   The caps are the key, the leds or CFLs are the Joule thiefs, but are also are drawing the energy in, and making it ring, for a while.  But, doesn't this need to be an Open Circuit,  to run like we want it to?  Or does it???
  I can also show pictures of my caps being blown out, with no heat ever noticed.  Once they do bulge and leak they are done...
  What we need is to find the way to use the Capacitors as if they are batteries.  They may need to be vented like some batteries, so they don't bulge and bust, and their electrolyte refilled if needed.
   The bulging caps effect will be noticed to a higher degree when running the Captret at 20 -30 volts,  and using several leds as the load. The type of Led does make a big difference, as they will hold the device down to their own working voltages and specs,  like a resistor.
   I've also connected the Captrets to a Jtc, as Jeanna had mentioned to me to try a thousand things, I did,  but I've blown most of them...
   We may need to make our own capacitor banks, or,  buy the right ones that will provide for the desired effect without the drawbacks...
But the main thing is that there is something to the capacitors ability to draw energy out of the surrounding space.  And that effect has not been properly tested or proven, yet,  although I think that Tesla and others have mentioned something along those lines, many years ago.
        NZ
tagor
from his
mrh2o2
youtube account ?
his new account is here
http://www.youtube.com/watch?v=WLaKRgW9RnM
ibpointless2
@all
I've never had any of my capacitors blown up or leak and i have a hard time believing that they do. I only use new capacitors and i buy them from Mouser.com. If you're using used capacitors then you might be affected by the "Capacitor plague". This Capacitor plague started when some companies went cheap and used the wrong formula that kept the capacitors insides from leaking. The best thing to use is new capacitors, and i've never exceed 17 volts. Also stay under the voltage on the capacitor. As for stiffler try not to listen to much of what he says about the captret. Stiffler like to post bad things about it and spread lies about it due to the fact that the captret idea got more attention than his similar but very different idea.
As for the extra energy i've concluded that its coming from the ambient heat energy that surrounds us. This would prove why some of my experiments don't work that well in my cold room, but put my hand over the capacitor and the voltage starts to go up. All seen here http://www.youtube.com/watch?v=fBPAKNUWiAs
