Captret - Capacitor and Electret
Started by ibpointless2, October 19, 2010, 06:49:51 PM
hartiberlin
Have a look at this.
Samsung makes 100 uF 10 Volts Ceramic capacitor as SMD parts
with Y5V type material.
http://www.beck-elektronik.de/index.php?id=mlcc-keramikkondensator
hartiberlin
Here is the samsung cap part details:
hartiberlin
Wow,
I did another test with my 10x 100 nF cap bank
and precharged it to 10 Volts DC.
Then I heated it again and it easily went to 30 Volts DC !
Wow,
this concept has really potential !
Also I am reading in Wikipedia that the Y5V material has
a good selfcharging effect of about 2 %..
So this is probably already from converting the normal environment heat
to electricity.
This will get a really cheap thermo to electric generator concept now.
The next question will be what the efficiency will be, but this
all has to be tested.
Regards, Stefan.
DreamThinkBuild
Hi Stefan,
A hair dryer uses about 500+ watts. Do you think painting the caps flat black and using a couple infrared or small 3v laser diodes to heat them will give better efficiency?
blueplanet
I am not sure whether you are referring to negative temperature coefficient of capacitance. There many non-electrolytic materials capable of yielding higher capacitance when subjected to heat.  Barium Titanate is one of those having negative temperature coefficient of capacitance at room temperature.
This self-compensating effect is well-known and being used in today's satellite technologies. This thing is nothing new, but I doubt if this knowledge is directly applicable to captret.
Self-compensating is not necessarily self-charging. Take a look on the following equations:
Q = C * V
dQ/dT = V * dC/dT + C * dV/dT
If Q does not change (i.e. dQ/dT=0), decreasing capacitance (i.e. negative dC/dT)  means increasing voltage (i.e. positive dV/dT).
But I believe the Q does change in some situations.
Quote from: hartiberlin on January 23, 2011, 05:33:53 PM
Wow,
Wow,
to electricity.
Regards, Stefan.
