Captret - Capacitor and Electret
Started by ibpointless2, October 19, 2010, 06:49:51 PM
Casstete:
You did repeat several claims, and I assume that you meant them.  Those claims when scrutinized properly fall flat.  For example, the pulse motor claim about drawing less input when there is greater output into the charging battery is a classic.  The people that do that are forgetting to account for the lost power as heat.
Some types of capacitors spontaneously self-charge.  There is energy in the air.  I think that is were the answer to the "captret mystery" could be found.
This is the thought experiment:  Someone has a nice bench experiment set up that they believe is over unity.  They call in someone for a second opinion.  That person makes proper measurements and gives a logical explanation for what is happening.
casstete
Quote from: MileHigh on June 25, 2014, 07:22:59 PM
Casstete:
----  the wheel spins faster ! and draws less , goes together yes -----
O for fucks sake , try and read yes . This device is tested by Cypriot Electrical PHD's who studies in renowned British Universities .
Cyprus has the 2nd highest academic population the world FYI and these guys tested iy ... not someone !
Then they left it for 2 MONTHS locked ( by mistake ) switched on ... and it is still running today 3.5 months later .
IF you make ANY changes to how many Leds are connected .. or remove one or the other capacitor it looses potential .
Yes there is energy in the air and yes capacitors always have potential when heated as they are chemical based as well .
I know this as a layman as well but the thing is they using a 12 V battery ( I told him ... maybe it's just cause it has more to offer that it runs longer ) but 3.5 Months ? still charging when using electricity ... all Lights ( 22 LED ) still shining bright .
The Battery only goes to 10 Volt so it's not even optimised .
The Captret is based on a Tesla Switch yes ? So the switch is just creating a potential " to be absorbed " BUT you have to create a receiver for this energy .
THIS is what has always been the problem , creating radiant energy from very little is easy .... capturing it or converting it is NOT .
Thats why Plants & humans + animals are designed the way they are , we are precursor engineered for such devices .
ALSO , is a 3 Volt Battery the same as a Lead Acid 12 V Bike battery ?
I was skeptical because I know the captret depletes .... but we had discussed atmosperic antennas placed in the circuit and also reverse tesla coils potential to absorb IF you have a ionised circuit ( i hope u get what i mean terminology may be off )
And the 12 Volt battery doesn't heat up absorbed energy .
Ok so point is .... heat of capacitors does not account for 3.5 month 22 LED brightly lit & 10 Volt constant recharge .
Does it . ONLY thing you can say is SHOW IT .
And that is true and I am working on getting him to make a second one as the prototype is locked away for holidays "still running "
regards
casstete
Casstete:
Thats exactly where you didn't read properly , the second part " call someone for second proper opinion " is the Cyprus Island wide comity of engineers who choose which project wins  ... they checked it and awarded the prize
AND they were told by my friend that it was based on IBPointless2 device ...  So it's not even me or my friend telling you this it's UK University educated PHD's ... who are still thick in my opinion but since that what you think is required ( in some respect i agree ) but in general they are totally brainwashed foold .
The longer you stay in school ... the more you become a indoctrinated fool
I want to see some data that demonstrates this claim that "bedini motors run faster during the full moon."
Data that supports that claim would have to show RPM readings taken from a Bedini setup, powered by _the same regulated power source _, during each day of the monthly lunar cycle and would have to show a significant difference between the RPMs at Full Moon and at New Moon, at least. Where is this data? A single graph of, say, a year's daily samples should show the effect easily enough.
Where is the data to support this claim?
If you cannot support the claim with real data, you have no business making it.
Qwert
Quote from: casstete on June 22, 2014, 04:43:31 PM
IBPointless2's device in combination with a Tesla coil ( reverse ) won a science fair for Students in Cyprus .
casstete, would you like to provide a link for this info? Thanks in advance.
