New permanent magnet motor on youtube from Roobert33
Started by hartiberlin, November 17, 2010, 05:47:43 AM
Omnibus
Quote from: lumen on January 04, 2011, 08:00:00 PM
The "Eden Project", I tested this about a year ago and found the major error they made. They used spring scales in their testing! I performed the exact same tests with the same 3/4" square magnets and found no difference in energy at all. Everything balanced perfectly using a digital scale.
I originally had nearly exactly their same results until I noticed the plastic handle stretching on my digital scale and causing small position errors in the magnets when under high tension.
I modified the scale to provide a solid steel mount directly to the measuring unit to remove any spring when under high tension. I tried the tests several times after that, but all gain shown previously was gone!
You will find a difference, however, using even a digital scale if you study the magnetic propulsor. You don't even need a scale to see there's a difference and the work depends on the path.
neptune
@lumen. Thanks for telling us about your experimental results . Just shows how easily we can be misled .@Omnibus . Could you please  provide a link to the Magnetic Propulsor .
Omnibus
This one proves the obtainment of excess energy in a closed loop:
http://video.google.com/videoplay?docid=5163427245750490858
You can also observe excess energy generated in steup like this one
http://www.youtube.com/watch?v=RKyGDWeblQw
You may also take a look at the one posted by @CLaNZeR in this very thread:
http://www.youtube.com/watch?v=vCJqFMNejrc
spinn_MP
Quote from: Omnibus on January 05, 2011, 08:52:01 AM
Oh, gee, Mr. Hand is still confusing the retard....
Omnibus
