New permanent magnet motor on youtube from Roobert33
Started by hartiberlin, November 17, 2010, 05:47:43 AM
Scorch
Quote from: roobert33 on November 04, 2011, 02:26:40 PM
Roobert33 isn't  "Mr.Robert H. Calloway"
Really?
Interesting!
Welcome aboard.
Hope you can help.
Please forgive my skepticism but; by all outward appearances, of Mr. Calloway's web site, it would seem he has SOMETHING to do with it even if its not his original engineering.
Are you claiming to be the same Robert33 who built the device and produced the video?
If so then I accept your claim on condition you answer some questions regarding 'your device'.
Should you fail to answer these questions honorably; then my acceptance is hereby withdrawn and you may be judged by all paying attention here.
-Why have you waited nearly a year to create an account and make an appearance here?
-Why is your device on Mr. Calloway's web site as one of the "projects"?
-Are you willing to answer some specific questions regarding this device?
-Are you like those of us trying to help the future of this planet by exploring alternative energy systems?
Please forgive me for asking all this.
Kindest regards;
Scorch.
Scorch
My main interest, right now, is merely to replicate what is in the video before attempting any changes.
As far as I know; nickel is not a ferromagnetic metal.
And nickel plating of the ferrite rods is more likely for appearance, and preservation of the ferrite materials, than actual performance.
I have seen both the videos you linked.
Still waiting to see a self runner.
The challenge you are faced with, by using magnets instead of ferrites, not only will your rotor be heavier, there will be a much stronger pull against the stator and trigger magnets which means the cam will have to work a lot harder typically resulting in a stalled rotor.
Roobert's original design is very lightweight and requires very little attraction to turn the rotor.
Everything I have "shared" is simply my own observations* of the video and what little I know about the behavior of magnets.
*One of the very first things I noticed in the video is a classic "hour glass" reflection on the end of ferrite pieces.
This is strong evidence these are not neodymium magnets. But, in fact, a machined part.
What is amazing to me is that, after 500+ posts, and many attempts to replicate, nobody even mentioned ferrites in this forum for nearly a year.
That is not until I came in here and brought it up.
This despite the fact its right there on Calloway's web site.
And then, suddenly, just a few days after I posted here and provided a couple pictures and ideas, roobert33 magically appears and makes the astounding claim that Robert Calloway is not roobert33...
What should we think about this?
Why this sudden appearance after all this time?
And if its not Calloway's project; why is it on Calloway's web site?
Is he merely another observer of the device video such as I?
Have I said or created something that hits really close to home?
Did somebody pester Mr. Calloway to the point he created the roobert33 account just to make this statement?
I am merely an explorer with many questions; not answers.
Quote from: Arrow on November 03, 2011, 05:32:04 PM
Hi dear Scorch, please find my step by step answers below to you post.
OK thanks, now I understand but , sorry, as far as I am going to get power from dram I need to use Neo magnets at the both sides to have more torque. see this http://www.youtube.com/watch?v=kCr3lOhMJCg and this http://www.youtube.com/watch?v=YIEJ0vMnhjg and my first try from HDD magnets http://www.youtube.com/watch?v=tlsLBikVerE - it is my inexpencive testbase. I am "playing" with this rotor everyday:) It is from the EPP foam. I made it on my own construcrted Foam CNC hardware in 2 min:) I am going to upload new video to my channel MrArrow1961 soon. So, you will be keepposted if come to my Tube sometime..there is my videos about my own used technologies, RC fligths, my Cad software research and results, lot of learning materials about CNC ,Rhino cad's etc. Thanks for watching Sir!OK, understand, thanks for information about the ferrite nesting place:)
Ferrites that are not plated with Nickel will not work in magnetic field effectively based on the known  causes â€" magnet will pull more effectively if it has in front of it more ferromagnetic metals such as iron, nickel etc.  OKThis ferrites( if I will find nickel plated once)  I will check up at the next project of mine, not at this timeYes agree.Yes agreeThis video is very good demonstration how magnet-magnet V-gate is working. Same effect we have in Roobert33 motor, but less powerful I guess as fаr as we will not have there 2 side V-GаÑ,е magnet energy sum, that is my firm belief based on my own experiments with V-gate shape installed magnets and clear, non magnetic ferrites.I put numbers on your question to simplify my answers if you don’t mind Sir:)
1)- My opinion - it is just nice and simple material that was used by Rob33, it is adding weight and nothing doing with mechanical or magnet field balancing.
2) see my opinion above at 1) answer
3) My opinion - If you mean brass short finger insertion into the ply of dram wall, then this is mechanical balancing to get first small moment to pass every time  dram it self like “flywheel”  dead point.
This is most difficult part to find exact place (point) to put it in every new dram like that.
4) each magnet line of at V structure has same pole e.g. let say left side N pole on the top and right side S pole on the top. When you will try to install them from Neo you will get force that will arrest your movements and exact targeting of magnets at their place. So be prepared to stand against of that confrontation force as far as by my calculations gap between the magnets only 2mm for D= ½” magnets. If you are going to use smaller magnets then reduce that gap to minimum to get approx solid magnet line from all magnets. As minimum gap between magnets that less subsidence of polelines between them.
5) see my answer above at point 4)
6) About top magnet - dram North side magnets has to see above same pole â€" North and dram South V-gate line has to see above same pole â€" South
About bottom magnet â€" I am not sure, need to construct my dram to check it, but to run a few steps forward I will copy the same position for bottom magnets to dram as the top one.Not agree:) I made it, its working as I said above, try to use may experience, guess and hope you will become happy to see easy result just with 1 bullet shoot:)Agree, just all magnets or ferrites  has to have sharp same height and other dimensions. Height is most critical staff. Take a note.Well, dear Scorch, V-gate principle IS WORKING, believe me, I am not bad and alive Armenian engineer with old "Soviet" wide knowledge base:)
Thanks for your information and help to me, I really appreciate to communicate with you and be effective and helpful for your project as well with my shared information. Shared info coming only from my own experience, no advertisements , no tricks, not an idea â€" just from practical working experiments.
Hope my post and answers will not disappoint by its content Mr. Robert H. Calloway. This long lasting post was only my tech opinon and I love to know if it will be loved by my namesake - Genius Engineer from Texas Mr. Robert H. Calloway
P.S. If only nickel plated ferrites on dram working with up and down magnets at motor it means for me that Genius Engineer from Texas Mr. Robert H. Calloway show his tuff middle finger up to any fundomental knowledge base man in the all over the World! Thanks Rob!
Truly
Rob
Arrow
Quote from: hartiberlin on November 17, 2010, 05:47:43 AM
Hi All,
what do you think about this video from
Roobert33:
http://www.youtube.com/watch?v=FLek_3Hpwus
It reminds me of the principle of the Finsrud machine,
but here puts it to work as a real selfrunning permanent magnet powered
motor.
Is this the holy grail we have been looking for ?
It seems to combine magnetic fields and gravity fields to produce
a working magnet motor.
Please comment.
Many thanks.
Regards, Stefan.
Hi dear Stefan,
as far as you are administrator here and can see almost everything in server communication traffic you are kindly asked to help us and verify - confirm if new user named as “roobert33” is the same person that pass this motor video to you to put it in your youtube channel?
Thanks in advance for help Sir
P.S. to roobert33 - Sorry Sir for such question to forum admin.If you are really Roobert33 then there is no problem for you and it is grate honor for us to see you in this topic even after 1 year!
Dear roobert33 are you English speaking man???
You know we know by heart motor Creator right hand from video. Are you able to make new picture of your right hand and share picture with us to verify your motor owner personality?
If we will not have here any verification from you or forum administration guess nobody will continue communication with you Sir.
Thanks in advanced for right understanding in such verification.I am engineer and need to know if I am speaking with motor author do not loose time and efforts
Truly
Rob
roobert33
Hi, I will answer to your questions, give me a few days. Thanks!
Arrow
Quote from: roobert33 on November 05, 2011, 09:03:01 AM
Hi again dear Rob, are you able to make new move for 10 min with same motor and upload it to Youtube again?
Why I am asking - at the end I had noticed some RPM auto degradation and then you had stop rotor.
I need to see if it is possible more longer behavior of running rotor.
If I am asking too much from you, then take my deep apology Sir
Truly
Rob
P.S. by the way such new video will be good verification that Roobert33 is the same person with roobert33 here.
If you are in trouble with video huge size for 10 min then I can recomend you to download and install nice, small and free software
here - http://atube-catcher.dsnetwb.com/video/
It has built in video converter (drug and drop window) and able to cut big size videos to very small ones almost without loosing video and audio quality.You just need to choose in video converter this codec, it is Youtube relevant format.
http://s017.radikal.ru/i439/1111/1f/7c2586ad1d54.jpg
