Ground breaking work of Frank Znidarsic (Cold Fusion & Anti-gravity explained)
Started by gravityblock, November 19, 2010, 01:34:22 PM
fznidarsic
I did all I could with a plasma.  Frank Staenger and I tried everything, I even went into a submarine and looked around.  Here is the link.
http://www.angelfire.com/scifi2/zpt/chapter2.html
I am trying to come up with some new ideas of my own right now.  I believe that Rossi has beat us all to the gate.
Frank
gravityblock
I've been doing extensive research in this area and I know Rossi's method.  Cold Fusion or LENR may be an inter-dimensional phenomenon.  When the temperature is exact there is an endothermic reaction, thus the reason for stimulation to get the process started.  Take a look at Rossi's patent, he describes an exothermal reaction, which is the opposite of an endothermic reaction.  Endothermic describes a process or reaction in which the system absorbs energy from the surroundings in the form of heat. The opposite of an endothermic process is an exothermic process, one that releases energy in the form of heat.  An endothermic reaction explains the lack of radiation in LENR.  There is excess heat generated in LENR.  This in no way invalidates Znidarsic's work.  If we can find a relationship between the Avogadro constant to the 1,094,000 m/s, then Znidarsic's work can explain this inter-dimensional phenomenon.  According to wiki, the precision of the Avogadro constant is the uncertainty in the value of the Planck constant.  Since this is the case, then it's directly linked to the quantum transitional speed of 1,094,000 m/s.
Phonon Resonance is responsible for the endothermic reaction.  I have the math equations and the resonance frequencies of all the elements to back this up.  Frank's work is related to phonons.  A phonon is a quantum mechanical description of a special type of vibrational motion, in which a lattice uniformly oscillates at the same frequency.  This vibrational motion within the nucleus of an atom produces a mechanical wave at 1,094,000 m/s.
Rossi's patent also refers to transmutation.  The conversion of one element (specifically one isotope) to another through a dimensional reaction occurs under select conditions of phonon resonance. Dimensional phonon resonance occurs when the space occupied by one isotope is exactly the same as that of another isotope in its rest state. This event only occur under the following two conditions: the expansion of an isotope by heating; or, the contraction of an isotope by cooling. Due to the natural characteristics of elemental properties, this event is extremely rare and one can only force the event under select conditions.
In subsequent postings, I'll release the phonon resonance frequencies for all the elements along with the math equations.
Here's a link to Rossi's patent,  http://lenr-canr.org/acrobat/RossiAmethodanda.pdf
Thanks,
GB
gravityblock
Phonon Resonance Calculator, http://www.overunity.com/index.php?action=downloads;sa=downfile&id=456
If you have issues with downloading the file, then please leave me a PM.  I'll post the math equations next.  I need to convert them into a format in which this forum can accept since there is no latex function available here.
Thanks,
GB
gravityblock
To determine the phonon resonance of an isotope, it is necessary to apply the following formula:
whereas, d - Density in gm/cm3
Na - Avogadro's Constant
m - mass
Equation 1 of 4:
gravityblock
By determining the inverse, one will observe the linear atomic spacing.
Equation 2 of 4:
