Ground breaking work of Frank Znidarsic (Cold Fusion & Anti-gravity explained)
Started by gravityblock, November 19, 2010, 01:34:22 PM
gravityblock
@All:  In the Excel sheet I posted earlier, there are 4 tabs at the bottom for additional functions and data.  I attached an image to this post showing where the tabs are located.  The tabs are labeled, "Periodic Table Phonon Resonance", "Conversion Calculator", "Temperature Calculator", and "Results & Graphs".
@Tempest: The excel sheet should be helpful in determining alternative elements to be used in LENR.  We need to find elements giving the highest excess heat production for the least amount of input energy with the least amount of costs for the elements. Hopefully Znidarsic can be helpful in this area.  If not, then we'll have to figure out how to apply this ourselves.  It may take a little time and research, but it should be workable since we have the formulas and phonon resonance frequencies for all of the elements.  The more people who gets involved, the quicker we can apply this.
Thanks,
GB
Tempest
So Gravity, from your charts, do you think something like this might work? I know that Mr. Z said that he did every thing he could with Plasma, but I keep looking at it because of the cost of the experiment.
This would provide the heat, light and correct freq. (if your calculations are correct)
gravityblock
Rossi's patent states a nickel powder, even of nanometric dimensions, or nickel granules or bars is used and the nickel powder contains catalyzer materials.  The powder will increase the surface area where the LENR's are taking place as suggested by the "Infinite Energy" publication.  Also it states the temperature should be preferably from 150 to 500o C, but it can be a variable.  The phonon resonant frequency is the linear spacing in reference to temperature as calculated by equation 3 of 4 in Post #40 .  The below screen capture for nickel will help to visualize this.
GB
gravityblock
Quote from: Tempest on January 30, 2011, 09:32:15 AM
Is that a no in your opinion then??
I wouldn't rule it out.  I need more time to digest all of this information.
GB
