machine converts plastic into oil @ 20cents a litre
Started by jikwan, November 21, 2010, 01:16:33 AM
ramset
Resin
It's An OU concept of sorts?
Gives the poor man a resource he never had,turns Garbage into a product!
I do see why it would be hard to "Mainstream",or get investors and such,The regulations would regulate it into a loosing proposition in no time.
However It has great potential if approached in the "smart"
way.
ie, from an environmental perspective and recycling a resource previously considered "garbage"[gov't funding]
To know the Cycletime from start to finish ,garbage in gas out /watts used per liter  of gas ,would be great!!
Chet
Thanks Grandma
ramset
Jikwan
I see you fixed the link!![or it fixed itself]
Quote:
One kilogram of plastic produces almost one liter of oil. To convert that amount takes about 1 kilowatt of electricity, which is approximately ¥20 or 20 cents’ worth.
From Here
http://ourworld.unu.edu/en/plastic-to%20-oil-fantastic/
A No Brainer!!
Chet
PS
ResinRat what would the byproduct be
Could we play with this here??{a Hillbilly still of sorts?]
Edit
Would be really cool to use the sun [parabolic dish and focus lense] to heat this up!!
Thanks Grandma
jikwan
it gets interesting.......
Giant microwave turns plastic back to oil
http://www.newscientist.com/article/dn12141
part of the article.....Similarly, running 9.1 kilograms of ground-up tyres through the Hawk-10 produces 4.54 litres of diesel oil, 1.42 cubic metres of combustible gas, 1 kg of steel and 3.40 kg of carbon black
they have these fantastic machines and we
dont know of it?
zen is the art of seeing everything and noticing nothing
ResinRat2
Quote from: ramset on November 21, 2010, 12:12:07 PM
Edit
You would need a lot more than sun to heat it up. Getting a container-full of plastic would have to be heated above 450°F. I have never broken plastics so I have no knowledge of what it would take exactly. Talk to a Chemical Engineer.  Since plastics are long hydrocarbon chains you are breaking the bonds into shorter chains. Gasoline is like 5 to 12 hydrocarbon chains, and these would boil over in the distillation unit as soon as they are formed. LOL!  I guess this is like a hillbilly still. In a hillbilly still you are boiling over ethanol, which is a two carbon alcohol.
Chevron lists the boiling point of their gasoline as 100-400°F. So as soon as the plastics start to crack you will be boiling over the by-products. You will also be getting off gases like methane, ethane, propane, and butane. These will be lost. Pentane is highly volatile but will be one of the first liquid portions formed. Then come the other hydrocarbon liquid chains.
This actually seems interesting. Collect all the plastics and form your own volatile gasoline mixtures. It would be hard to do quality control though. You need to do fractional distillation to further refine the mixtures, and this takes more specialized distillation equipment. Maybe not too possible for the backyard "still" type of chemists (LOL!). You don't want to form "Racing Fuel" to use in your car; and unless you can further analyze the mixture by using Gas Chromatography you will never know what you have.
This might be better handled by Companies set up to do this type of refinement.
RR2
ramset
ResinRat
____________________
I've heard of old satelite Dish's doing hotter [covered in Mylar]
But have a look Here
http://cleantechnica.com/2009/08/30/backyard-solar-dish-melts-steel/
Thanks Grandma
