HHO watergas, very low power water electrolysis !
Started by hartiberlin, May 12, 2006, 09:05:55 PM
TheOne
if you look at the patent http://v3.espacenet.com/origdoc?DB=EPODOC&IDX=WO2005076767&F=0&QPN=WO2005076767
but in page 64 (fig. 20)
you will see its probably like all the others cell out there, one side (half of the SS plate) are connected to - and the other half is connected to +
hartiberlin
Yes,but it is said, that this is just an OPTION.
The normal generator from them seems not to have it.
There are the additional plates NOT connected, thus
lower input power required !
mikestocks2006
On page 4 it states that it produces 55 scf at 35 psi using 4KWH.
Does anyone know if we plumb this gas flow into a high efficiency gas powered, electical generator, will it produce at least 4KWH using the 55 scf of the gas produced by the device?
If it does then that's it! Not an overunity device per se, but a device that produces excess power using only water.
TheOne
i will need to try this this summer, today i found some cool 4"x4" SS steel plate at RONA for 0.95$ (CAN) each. they have 2 holes, its like they have made this plate for hydrogen cell! :)
since my jeep v8 4.7 L use a lot of gaz, i will need to find out a way to decrease the gaz cost! at least i was able to increase the mileage (18-19 on higway) now its 22-23! but with an hydrogen cell that will increase more "hopefully"
joe
Hi The One,
You said that you have found some SS steel plate at RONA??
Can you tell me in which section of the store you have found it. Cause here in Gatineau's store I can't find any.
Thanks   Joe
