Weight with springs that add speed to the gravity wheel???
Started by frii143, December 19, 2010, 03:40:36 PM
frii143
Hi,,,
Would springs with weights on them that adds a bounce on half the side of the gravity wheel and don't bounce on the other side of the wheel create a turning wheel??? Thanks,
khabe
Look at http://www.offtop.ru/khd2/view.php?part=19&t=694912
You need hose, two wheels .... number of bellows and water will do the rest  :o
cheers
frii143
Hi,,
I seen online some where a while ago that in India they had put a Gravity Wheel out on the ocean and the waves caused the gravity wheel to turn a little at a time. Today I thought what if they replaced the waves that osolated the gravity wheel with springs. Thanks,
frii143
What if the platform was spring loaded to allow the gravity wheel to spring back and forth to oscillate the wheel. The had yo-yoing weights from springy material they spring up and done on one side of the wheel and not on the otherside of the wheel. The gravity wheel only turn in one direction?
