Selfrunning HHO system with 400 Watts additional output
Started by hartiberlin, December 23, 2010, 10:34:37 AM
vrand
Quote from: cubalibre on February 23, 2011, 04:41:32 PM
@Mike
Almost all about building an ANTON drycell, operating data, tips and tricks, modification and data of the generator, waste spark elimination, ...
is open source presented by the inventors on the German forum.
Link: www.overunity.de
The information are placed in different threads, on topic and off topic, developing during months, therefore not easy to find. A few members are right on the way to replicate the selfrunner.
As well 2 Series of ANTON cells were built especially for the forum members, therefore about 40 users do have a high performance HHO drycell now.
Meanwhile woodpecker helps to build drycells of similar quality in his workshops.
regards
cubalibre
Thank you cubalibre. :)
Great to hear that the German forum is still working on this very interesting technology.  I will visit the site and read up on it.
Maybe the inventors will publish a complete instructions on how to build an electric generator unit and give it to Free Energy Researcher, Patrick Kelly, for publication in English.
Here is an example of a Patrick Kelly instructions on how to build a Bob Boyce 101 plate series electrolyzer cell:
http://pesn.com/2007/09/29/9500450_BobBoyce_Electrolizer_Plans/d9.pdf
Please let us know when the Anton cell, with electric generator set, will be for sale on the German forum.
Cheers,
Mike
Hope
Concerning using a 2 Cycle generator set.   First the need for lubrication is lessened with the operating temperature being lessened from 600 F degrees to 200 F degrees.   It has been show with other HHO burning engines that the lubrication provided by the HO gases is enough to provide a competent level of fraction controlled lubrication.   Any other input here is needed and should of course be researched.     Our fuel reactor is built now and the mods have be made to connect it to a 10HP 4 stroke gen set.   The HHO papers of Bob Boyce suggest the use of a LPG carburetor (Excellent Thinking!)  then the load correction can operate normally.   (and make this device able control variable load engine like cars)  Processing the HHO through the Pantene/Naudin proof of concept fuel reactor will increase (as proven in France) our usable HHO another 30% . Of course the proof is not in hand (for me) until we build the TPU Bruce's (the mogul) designed and incorporate it with the fuel reactor.
grizli
LES BANKI and all others (who can answer)
WHY gas engine can be looped using HHO, but when I burn HHO heat energy is inside Faraday "parameters". For example if I have 99% faraday cell heat energy from HHO burning is lower than eelectric energy needed for HHO generation.
BUT it is clearly shown by many inventors that amount of HHO needed to run gas engine is QUITE SMALL for example 3-6 LPM for home generator unit (like this man from Germany)
So whats going on inside gas engine when HHO is there?
bolt
When HHO is ignited under great pressure like 150-200 PSI with ICE the power is greatly magnified. Like when you trap HHO in a container then ignite it the explosion almost takes your roof off! Anyone that tries to store any amount of HHO in containers at pressures over 7 PSI has just made a lethal weapon particularly where its raised to pressure like 100 PSI its highly unstable and will try at any time to convert all that energy back to water.
HHO recombination is an electron migration process where water is used as a Zero Point Energy proxy. So the water is not actually the fuel even though it will consume water. For all practical purpose who cares it uses water?  As HHO burns thru metals and raises to thousands of degrees the process has been measured as OU as electrons are accelerated at huge speeds form kinetic energy bombards the adjacent molecules in the material being heated and the temperature is raised several magnitudes hotter than the HHO flame itself.  The process is improved higher by high voltage spark at flame point as within Atomic Welding. High voltage spark adds abundance of free electrons.  See early 1900's books already recognised this process as OU.
For HHO heaters use rock ore materials with high crystal content not metal. As crystal excited by extreme heat the crystals are energised release more and more high speed electrons as piezoelectric effect into adjacent material heating >3000 degrees. The process goes OU. Special cut rock is then built up around the heat chamber to make a HHO core reactor. Then conventional fire bricks cover the stack to make a 300 degree IR radiant heater.  Several patents on this already.
Typically the HHO yields a COP 3 within ICE when all the other parameters have been perfected for engine timing etc.
So if you put 1000 watts into your cell you have 3000 watts of energy within the engine. Take off 1000 you need to give back to keep the cell going plus engine losses, friction and alternator conversion loss etc so total you need to give back 2000 watts of this energy. Now you have 1000 watts OU available to run a load. You can see by making engine super efficient you have 1000 watts here which can be recovered rather then giving it back as losses so as the process is refined you get over 1000 watts OU.
Now you can see without any PWM driving and special tuning already the process has a COP 3. By using PWM high frequency drives, ultrasonic water fog injection, resonance tuned alternator, the COP can easily exceed 5 even higher.
So if you perfected everything and used PWM etc reaching a COP of 10 within a car engine is not impossible in fact its very achievable as others have done this already.  You need a 5kW cell to get 50kW out the engine running only HHO and nothing else. Perfect for a small car.
grizli
Quote from: bolt on March 10, 2011, 09:00:47 AM
I know that some people completely safe  use HHO dry cell under 30 psi to remove foam and bubles and make better liquid flow(without buble saturation).
so it is claimed that its safe to operate cell at 30 psi level , which also increase HHO production. Remember Even Stanley Meyer had his cells under pressure.
If HHO COP is above 3 inside gas engine, why closed loops are announced so late ?
Classic gas engine has les than 30 % eff.. maybe HHO works cooler and eff is higher.
First page of this topic, original "german video" "self running generator in elevator" , do I see it clear , but it seems that HHO tube goes directly into engine WITHOUT any air? So this would man engine works at 100% HHO , am I wrong here? BB , Les Banki and all others claim 99% air and 1% hho is great ratio.
I have never seen that simple PWM without any "back emf effect" (inductor needed) can produce greater eff. PWM justs makes current to be at your own desire.
Question is HOW to get 3 X Faraday COP? You say that 3 COP is HHO inside gas engine. So we need another 3 COP above Faraday for cell itself.
Is there any 100% proved 100% every time successfull method for making HHO cell that can have 3X or more faraday ? (using pwm)
Now HHO heater?
Maybe just what is needed is that we heat some material above some point... I made experiemnt myself and heating water cointaner = NO OU., but maybe if we heat piece of metal that becomes glowing we get OU (process you described)
Do you have any more data about Rocks needed ?
What about HHO and Propane /butane mixture. Some people from Italy slaim that this way HHO small amount makes butane have 18 time more BTU !!! ?
