1 kW zero point energy @ Peswiki.com
Started by Low-Q, February 10, 2011, 07:48:07 AM
e2matrix
A quick thought for those needing variable capacitance.  This could apply here or any projects needing this.  Old Ham radio antenna tuners can sometimes be found for cheap.  They often contain one or two large variable caps as well as coils.  If you can get in the ballpark with a fixed cap and then put this variable tuner in line with it you may be able to more easily dial it right in.
LightRider
Quote from: e2matrix on February 11, 2011, 01:05:29 PM
like this?
LightRider
e2matrix
Nice.  Looks like that one is made for some fairly high power.  :D
Low-Q
Such open capacitors have very low value - maybe in the nano or pico farad range. It will change capacitance with temperature and humidity as the dielectrium are just an open space of air between the plates. These capacitors are designed for very high frequencies - in radio recievers, as an example.
