MAHG by jlnLabs
Started by wizkycho, May 22, 2006, 02:01:41 PM
wizkycho
   Soon as I get my hand (purchase) some Current Clamps measuring instrument and finish experimenting with hydrogen and oxygen mixture
(which will end as hydrogen boost in my diesel car), I'll jump on replicating astonishing MAHG
that needs to be made with simpler housing (thinking copper pipe (water runs through it) winded in cylinder around tungsten). Scince Jean Louis found out that smaller the input greater the COP (from 5 Watts gets 100 Watts using only 20A not initial 60A), dont'think that Molybden is needed in contacts. Contacts only need to be made bigger in order to spread tungsten's temperature.
But there is one thing I would like to know that I don't understand from drawings.
How much tungsten wire (lenght) is actually in the rection chamber and where to purchase it cheaply ?
Thx
Igor Knitel
wizkycho
Hi All !
Well after a while found out I can not get hands on 0.2 - 0.3mm wolfram (tungsteen) wire
so I come up with an idea to use halogen bulbs.
Remove quartz glass by clamping with table clamp just to break glass and don't break tungsteen wire. that way I'll get open tungsteen
wire and connecting pins. 12 or more such prepared bulbs will be placed radialy (in circular fashion) and fastened with nuts.
see pic
it will all be sealed in copper disc (with some additional copper ribs) with welder for electronic components and tinol.(engl. word?)
What do all You think ?
for details and dimmensions open the drawing
Wiz
wizkycho
Hi all !
how to insert Hydrogen and make it underpressured at 0.1 ATM ?
Any practicall procedures for that ?
wiz
mscoffman
Quote from: wizkycho on October 28, 2008, 10:59:49 AM
Hi all !
wiz
My understanding is that MAHG core unit is packaged like a Power Vacuum Tube,
that would be, they pull a very low vacuum then use a getter to remove any remaining
oxygen. Once that is accomplished then they introduce the hydrogen. Otherwise the hydrogen
would recombine with any oxygen in there once the operating power is applied to the unit.
Really, you should try to try to obtain one of the 300 core units that were made by the Russians
and/or else get Power Vacuum Tube reverse manufacturing expertise. I'm sure that was
the model they used to produce it in the first place.
I wish you luck and it is an interesting overunity process.
:S:MarkSCoffman
wizkycho
Quote from: mscoffman on October 28, 2008, 01:00:05 PMReally, you should try to try to obtain one of the 300 core units that were made by the Russians
:S:MarkSCoffman
Of course oxygen will have "blow-up" potential so I'l be very carefull, like allways doing something with hydrogen - especially conatined in copper box !!!
Try to obtain one of  300 core units !?
- where to start and how are those core units made ?
Thx
wiz
