it's working?!!!!!
Started by pree5, February 13, 2011, 02:10:25 PM
Pirate88179
Conrad:
No, I never used the relay, that was an advance made by JonnyDavro and I never got that far with it.
On the Bedini with the motorcycle batteries, I used a 470 ohm base resistor and two 5k pots.  On my One magnet (JonnyDavro's replication) device I used a 100 ohm base resistor and a 5k and a 2k pot.  (It was all I had laying around)  My neons on both were, I believe, 80 volts units.  (Possibly 70?  I am not totally sure)
JohnnyDavro's Bedini's are the most efficient I have ever seen and can be run from a single AA battery, or as I did in one of my videos, an Earth Battery.  With the addition of that relay and his other modifications, it gets even better but as I said, I never got that far with it.
If you need anything that I have missed, feel free to pm me and I will try to look it up or find it.
guruji
Hi Pree nice work. How much windings did you do on that toroid?
Thanks
pree5
e2matrix
pree5,  thanks for posting this.   I have a couple questions.  What are the leads on the transistor going to - that is you have a gray wire, red wire and yellow wire.  Gray to Emitter, base or collector, Red to ? and yellow to ?  Also what is the winding setup on the toroid?  I assume bifilar but you have a third winding also coming off it for the LED.  Is that just to see if it is working?
friendenergy
Pree would you mind telling me what program you used to make your animated drawing. I think it's cool and would like to make some stuff like that too. thanks if you can.
