Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
ramset
A note to Folks here,This thread is only Half of the info
The rest is at Energetic,
Arron Mahacmedkowalski [probably misspelled his name]
Has a disagreement with "The powers To be" [AKA powerme]
Hopefully they can work this out ? in the mean time
Its Thread Ping Pong.
http://www.energeticforum.com/renewable-energy/7365-discussion-best-way-use-heat-hho-generate-electricity-17.html
Enjoy
Chet
PS
Post the link every now and then fellahs!
Thanks Grandma
The Power To Be
Quote from: ramset on March 09, 2011, 04:54:58 PM
Enjoy
Chet
PS
Thanks Chet.
EF had banished me  ;D
"Thou shall not commit fraud" thanks @ Aaron
I am not right nor wrong, it is only what one wishes to see.
@ Arron Mahacmedkowalski, can you please post your finding?.
thank you very much.
The Power To Be
Romo,
can you expand on your new ideas please, quite fascinating.
I only use positive charge for ionization, the beneficial result is well known, lots of old books that explains it, Influencing as it was called. The earth is already charged negative.
Thank you all for your interest and efforts.
RAD-HHO
Here are before and after pics of my second batch of crystals.  The first picture is after ice bath before cooking @ 60°C for two hours.  The second picture is after cooking @ 60°C for two hours.  Another definite increase.   ;D
The Power To Be
Great job RAD, not to discourage you but everything that you msay ever need to know has already been done and published and readily available. ZnO crystals have been researched for many different applications, which is great as it will save us lots of time.
For testing, it is best to use Air tight chamber and route gas to a small ICE, may be a small genset to power ultrasonic as well. It's a plus to develop speed reading, you can read all of the materials before hand so to have a vast library of your own refrences, it is best to work on your own so that you can observe what is happening without having others tell you of what they think, you can always look for the mainstream coined terms that best describes your observence.
Thank you Slovenia, the back up files will come handy someday.
Nature has remedies to aid with your dreams and manifestation of reality. Shaman uses them but I dont.
Romo brought up a totally different route to making HHO from ultrasonic water fog, the process is called Influencing. It is a very effecient process where very little current is needed. This process is still utilized in powder coating today but it's wider application has been halted due to other complicated political issues.
Anyhow, only the positive of high frequency high potential voltage is fed thorough spark gap, the negative is grounded. This spark is used to ionize large volume of air with very little energy input, and since our water is already semi gas, we can apply the same method here to produce HHO at very high effeciency.  The ionizer is very simple to build and it is robust and realively free maintenance, it consists of a simple TT coil and rectify vacuum tube, no semiconducter is needed.
Another method to produce HHO, thanks Romo.
