Shorting coil gives back more power
Started by romerouk, February 18, 2011, 09:51:45 PM
e2matrix
Coil shorting concept is really taking off.  Thanks Romeruk for showing this apparently easy way to build.
  One question about the magnet setup on the disk.  It looks like 2 magnets at each of the 4 positions.  Are those setup something like this (crude drawing)? :
        ______________
        |_S________N_|
        |_N________S_|
Edge or disk is at left of diagram.  If so are they in a configuration as it appears that they need to be forced together and wedged in place (or epoxied or similar).
   Or is it a single magnet in each of 4 positions with the N/S simply at 90° to the edge of the disk?
romerouk
Quote from: e2matrix on February 19, 2011, 12:15:57 PM
        ______________
        |_S________N_|
        |_N________S_|
I have used a single magnet in each of 4 positions. Having the magnets orientated this way reduces the drag.Even when I leave the coil shorted the speed is not affected.The coil used in my test is from a microwave fan with the original core. More turns, better the effect of amplification and less drag. The setup can be tested even in a normal NS setup.
I am working on a solid state version to be able to short the coil multiple times at every peak of the wave.
The same principle can be used in many variants. I think that Kapanadze is using something similar.
My 12 volt Kapanadze replication was based on the same principle. At the time I was working on that setup I had it working without knowing and understanding all about it.
Recently I tried to replicate my Kapanadze setup and after many attempts was not working like the original one.After playing a lot with it I realized that if the SG shorting the coil is not at the peak of the wave then I get nothing extra.At one point Kapanadze was saying that once the principle is understood the it can be applied to any setup, electrical, mechanical,...
Success everyone!
RomeroUK
penno64
Hi All,
How pertinent is this guys video now ? (1 and 2)
http://www.youtube.com/user/NRGFromTheVacuum#p/u/10/2cUS03yNl40
Looks like it's been under our noses all this time and we couldn't see the forest for the trees.
Kindest Regards, Penno
wings
Quote from: penno64 on February 19, 2011, 02:53:53 PM
Hi All,
and this ... posted by minoly on EF  ::):
http://www.youtube.com/watch?v=QRyKVU6YzYw
gyulasun
Hi Penno64,
I think what you refer to is a different principle in that it does not have a sine wave or sinewave-like induction or oscillation in the coil, ok?  I think your video link shows capturing the kick back from a coil when switching current on and off but what is involved here is inducing voltage by a moving magnet and when the induced voltage is at its peak values (either negative or positive peaks) then you short the coil by a switch and this is what enhances the voltage in the capacitor (after rectification).
See here some more on this (Doug Konzen site):
http://sites.google.com/site/alternativeworldenergy/shorting-coils-circuits
rgds,  Gyula
