Shorting coil gives back more power
Started by romerouk, February 18, 2011, 09:51:45 PM
gyulasun
Hi Romero,
VERY, VERY GOOD!  Thank you for showing the input current behavior.
If you need help in choosing MOSFET switch, tomorrow I can suggest some.
Greetings,  Gyula
Quote from: romerouk on February 24, 2011, 06:03:53 PM
Test with measurements.
Shorting the coil seems that is not affecting the speed or the power used to drive the rotor.
I am working to replace the reed with mosfets and a hall sensor.
http://www.youtube.com/watch?v=33IQaN-M27U
conradelektro
Thank you Gyula, your explanations (and the video you recommended) made things a lot clearer for me.
@romero: I am always worried about reed switches, their life is rather short. A hall sensor and a MOSFET would be great. May be one needs two MOSFETS, one for the positive and one for the negative side of the sine wave coming from the pick up coil.
Greetings, Conrad
MasterPlaster
Quote from: gyulasun on February 24, 2011, 06:13:57 PM
Hi Conrad,
If I may chime in, here is a video from which you can get some explanation:
http://www.youtube.com/watch?v=QRyKVU6YzYw
The video is a very good demonstration but there is a big MISTAKE.
There is a drawing shown at the begining of the video which shows a sine wave.
Note that the magnet passing the coil generates a uni-polar wave pulse and not
a sine wave.
Bruce_TPU
Hi Romero,
Quote from: conradelektro on February 24, 2011, 07:24:11 PM
Greetings, Conrad
I believe that Conrad is correct in the following...
You can double down on the effect by shorting the coil at both the peak of the spike and the center of the notch (negative). This alone should double your output.
Good luck!
Bruce
teslaalset
Quote from: MasterPlaster on February 24, 2011, 08:09:23 PM
a sine wave.
@Masterplaster,
This depends  on the North/Southpole orientation of the magnets that are used.
If they N/S axis is pointing to the centre of the wheel you will have a different waveshape than when the N/S axis is pointing parallel to the outer side of the wheel.
