Rosemary Ainslie circuit demonstration on Saturday March 12th 2011
Started by hartiberlin, February 20, 2011, 06:14:05 PM
fuzzytomcat
Quote from: WilbyInebriated on May 23, 2011, 02:41:56 AM
ahhh, how fickle the winds of "open source" contributors are...
a blast from the past...
quote taken from "the strange case of the rosemary ainslie circuit by steve windisch". full text can be found here: http://dandelionsalad.wordpress.com/2009/12/24/the-strange-case-of-the-rosemary-ainslie-circuit-by-steve-windisch/
"The gifted and skilled Open Source Researcher, Internet name “Fuzzytomcat” (Glen Lettenmaier), one of the first to Replicate the Ainslie Circuit successfully in 2009, has built several configurations of the special inductors/resistors for test… And his fine work in building, tuning, measuring, documenting, and analyzing test results… Extremely well recorded and presented using the Tektronix Digital Phosper Oscilloscope stored data, still photos, and “You Tube” videos… Conclusivly prove using accepted industry-standard methods that this circuit has definite anamalous qualities in energy efficiency, and that the Rosemary Ainslie Circuit and effect deserves very close scrutiny from our scientific mainstream community."
(emphasis added by me)
the interesting thing is... not so long ago, these "players" were lauding this circuit and placing heaps of praise upon rosemary (and themselves of course ;) ) and talking about success and "several replications"... but now, what are they doing? yes, a strange case indeed.
perhaps steve (jibbguy), glen (fuzzytomcat) or aaron murakami could clarify for us which case they have stated (since they now have made several different OPPOSING AND CONFLICTING STATEMENTS) is the correct one, and perhaps give the rest of the readers here an explanation or reason for the flip-flop...
It's on record all over the place if one was to look ..... also check the published dates about five (5) months apart
http://www.energeticforum.com/93746-post74.html    ( 05-02-2010, 09:23 AM )
Quote -
________________________________________________________________________________
Hey Harvey,
I'm sorry it took so long to do a detailed overview of the "LIVE" broadcast I did in the "Open Source Research and Development" channel on the January 9, 2010 5 Hour non stop video recording.
This video as you are aware is one of the best ever recorded representation of the preferred mode of operation but only in a non stop 5 Hour video. I'm sure that many members and guests don't realize the difficulty in capturing this effect for the purpose of recording the data properly and if given the time looking at the recorded video everyone can see the problems that we face in getting accurate data.
The constant 24 volt battery bank voltage fluctuations going up and down the Mosfet "drain" spike oscillating from 500 to 900 volts, battery voltage down the Mosfet spikes, battery voltage up the Mosfet voltage to normal operating range, back and forth over and over.
I have tried to get as close to this mode of operation in Test #13 which was used in the IEEE submittal Open Source Evaluation of Power Transients Generated to Improve Performance Coefficient of Resistive Heating Systems the team including yourself did, and in Test #22 but never being able to record the data scientifically correct because of the circuits complex oscillating waveforms. I don't think everyone, members and guests understands that the Test #13 was done with a Tektronix TDS 3054C which has a maximum resolution of 10K of data spread over a 10 x 10 grid or divisions so each one has 1k of data samples separately for each of the 4 channels. The data collected in Test #22 was with a Tektronix DPO 3054 which has a maximum resolution of 5M of data, but I used the 100K which is spread over the same 10 x 10 grid or divisions so each one has 10k of data samples separately for each of the 4 channels ..... ten ( 10 ) times the data of the TDS 3054C used in Test #13.
The problem being we need to find a method of capturing the data continuously in real time, there's nothing wrong with Tektronix TDS 3054C or the DPO 3054 these are the finest instruments I've ever used and are extremely accurate, but if you push the acquire button at the wrong time you can appear to get conflicting or skewed data, not the case .... were you before the spike, during the spike or after the spike when the data was collected. I had a allotted dedicated set time to record the data, It was the time frame I used with the 6 minutes or as fast as the data could be physically collected with the finest equipment I had at my disposal.
I am in total agreement with you that something "good" is happening in the Mosfet Heating Circuit and can be plainly seen in the recorded videos, we just need to somehow get a streaming real time data recording. Maybe by somehow obtaining a Real-Time Spectrum Analyzers from Tektronix or some other method to verify the data findings as you suggested, the equipment I previously used as good as it is, just isn't enough to totally capture what is occurring during the preferred mode of operation.
Best Regards,
Glen
My testing was on a MODIFIED replication ... http://www.energeticforum.com/84279-post1.html "NOT" the original circuit operating at a higher frequency with a made custom inductor.
Fuzzy
WilbyInebriated
Quote from: fuzzytomcat on May 23, 2011, 03:08:03 AM
Best Regards,
Glen
Fuzzy
care to explain what you meant by "good"?
oh!! my!!  modified!! you used a custom wound resistor? whoop de doo... did you change the fundamental design of the circuit? no. you didn't...  ::)
more from the "strange case":
Quote“COP” efficiencies greater than “4″ have already been recorded in the recent 2009 replications; and can be possibly much higher as the voltage pulse levels seen in the waveforms often go beyond the limits for measurement of the present equipment.
(again, emphasis added by myself)
stranger yet, i noticed nothing in that article about "modified" circuits, just "replications"... so who is not being truthful here? you or steve?
edit: and even stranger yet, you have now claimed there is no "technology" and that rosemary has 'nothing'. i can find those posts and rub your face in them if you wish. ;)
fuzzytomcat
Quote from: WilbyInebriated on May 23, 2011, 03:31:36 AM
more from the "strange case":(again, emphasis added by myself)
GOOD .... watch the complete five (5) Hour non stop video recording as posted ....
http://www.livestream.com/opensourceresearchanddevelopment/video?clipId=pla_6d255c76-9e9a-42ae-a565-fbc698e0b6df
Rosemary's COP efficiency claims are hers, not mine never were ..... so ask her about the
COP> 17 ???
COP> INFINITY  ???
The op-ed article was written by Steve Windish ..... ask him not me.
WilbyInebriated
Quote from: fuzzytomcat on May 23, 2011, 03:48:38 AM
COP> 17 ???
COP> INFINITY  ???
LOL you're funny glen. i've watched before... when it was first posted, and i am quite aware of what you, aaron, peter, steve, ash, et all were saying back then... something quite different than you are saying now... ::)
QuoteThe gifted and skilled Open Source Researcher, Internet name “Fuzzytomcat” (Glen Lettenmaier), one of the first to Replicate the Ainslie Circuit successfully in 2009, has built several configurations of the special inductors/resistors for test…
(again, emphasis added by me)
QuoteAnd that there are many possibilities for practical uses and parallel applications yet unexamined. “COP” efficiencies greater than “4″ have already been recorded in the recent 2009 replications;
this 2009 "replication" is referring to glen... ::)
funny how you have no problems with steve making cop>1 claims for your REPLICATION... ::)
fuzzytomcat
Quote from: WilbyInebriated on May 23, 2011, 03:56:00 AM
more from the "strange case"(again, emphasis added by me)
Please supply any FORUM posting link or number from ....
Aaron
Peter
Steve
Ash
Harvey
Myself
or anyone "World Wide"
..... of a verified replication on the Rosemary Ainslie finding or claimed efficiency of a COP> 17 device with all experimentation done in any scientific method reproducing the same or exact finding or claimed results by Rosemary that could be reproduced by anyone over and over again.
