DIY ACID FREE CARBON BATTERIES
Started by Bizzy, February 23, 2011, 11:05:49 AM
Bizzy
The following is another cell with the carbon finely ground. Although .08 volts may not seem like a big differance, it is an increase. And the water is still settling into that cell.
When I pooured the water into the granualr cells the water went down easily. However in the case of the fine ground carbon it is taking much longer to filter down. I am hoping by this evening it will be full and I can get better readings.
Bizzy
Bizzy
Good morning
I discovered an error last night. When I was originally setting up the cells my wife came in and I forgot to add water to the last cell which by itself was not producing any power. So as a result my original readings of 5.9 volts was just for 4 cells not five.
Each cell individually produces bewteen 1.49 and 1.52 (not including the new cell with fine carbon instead of granualar) If water would have been added to the 5th cell the power would have been much higher.
Just to prove this I hooked all the cells in a series this morning before work. In this I also included the new cell and I was getting 7.40 volts.
The new cell individual output was already to 1.61 volts. I will have more updates tomorrow.
Bizzy
Bizzy
Good Morning
As promised here are the results of all the cells hooked in series including the cell with finely ground carbon. 7.63 volts.
I know for certain it can go higher with the ground carbon, but there are still other tests that need done and the granular carbon is easier to work with.So I am going to leave the others granular for now
Bizzy
Bizzy
Hi Brad
I wanted to compare your idea of incerting the wire as you do compared with using the copper tube as I do. The following are those results.
In the following picture is a single cell using granular carbon and magnesium as before. I was hoping to use a galvanized tube and thought I had one in my workshop but didn't.
The voltage results were 1.51 volts.
Bizzy
Bizzy
continued...
The following is a picture of a cell using just a single wire in the granualar carbon. Just as the previous picture I used a magnesium rod. The only other differance is I removed the copper tube and used a PVC pipe to contain the carbon and water around the magnesium rod. The resulting voltage is actually 1.08 volts. This photo was taken the previous night.
But  I have to conclude that a larger contact area is needed to maximize voltage.
Bizzy
