HHO GENERATION WITH 1 WIRE, by Dr Stiffler.
Started by FatBird, March 07, 2011, 11:55:42 AM
FatBird
Click on this Link to see HHO generation with only 1 Wire.  AMAZING!!!
What if he placed a Paper Clip (or more copper) on top of the diode.  WILL MORE BE GENERATED????
http://www.youtube.com/watch?v=17xjF9cHDNc
BENEFITS:
1.  Simple expansion.
2.  NO heating of the water.
3.  Distilled Water with NO electrolyte.
4.  1 Wire means almost no power consumption.
5.  Diode can be driven directly IF it is fully immersed in the water.
6.  Simple construction.  EXAMPLE, why not use a cheap HV supply from a $10 disposable camera.
ResinRat2
Does anyone know if the diode deteriorates over time? I never read any information about that.
Dr. Stiffler should know this information because I am sure he has run long-term tests on this.
Mark69
What is a...
1. SEC exciter?
2. L3?
Does it look like there is nothing connected to the positive side of the battery, just an alligator clip?
crowclaw
Quote from: ResinRat2 on March 07, 2011, 12:52:41 PM
Interesting experiment... chances are that the leads would errode away fairly quickly!! how about trying several diodes bunched together and see if you can produce more gas!! I used stainless steel plates a while ago which was the most popular method. This idea is certainly different, try with a disposable camera HV flash circuit. Post results if you decide to give it try.
Poit
this video has interested me as well.... i find it strange though that this guy is stressing about how important this find is, and to spread the video far and wide... but ..... there is no follow up... nothing at all... no diy guides no more tests ... just nothing ?
MIB's? lol
