FREE ENERGY AC GENERATOR ?
Started by e2matrix, March 10, 2011, 06:02:45 PM
e2matrix
I found the article below in a rather obscure search and want to share it although I have doubts about it working and how.  I welcome discussion about this and seeing it would be very simple to try maybe someone already has the parts to try it unless you think it's completely bogus.  I'll post the entire article below and attach the simple circuit pic but I'm skipping the scope shots for now that were included in the article.  If there is interest I'll post them too.  I have no idea who wrote this or where it came from but it does reference a concept Stefan made public as well as a couple others whose ideas this person used.  Here is the article :
Introduction:
This device is based on some free energy ideas that finally seems to have
something in common:
-    The “split the possitive” idea by Edwin Gray.
o   It uses a battery and a circuit to get high voltage from it. The
circuit is comprised of Ls and Cs. Then, he let the stored high
voltage   energy   to   return   to   the   low   voltage   battery   again   (so
almost no waste of energy), and he uses electrostatic induction
caused by the storing and releasing of that energy to power an
inductive load.
-    The parametric power conversion ideas by Stefan Hartmann.
o   Changing   the   parameters   of   Ls   and   Cs   in   time,   the   energy
changes. The usual method is to keep the Ls and Cs constant,
and change the charges in time.
-    The electricity generating apparatus by Harold Aspden.
o   Using Ls and Cs, it is said the energy oscillates and can power the
load, because it is energy of the vacum.
The common elements are Ls and Cs.
Theoretical explanation:
Electric circuits work by depleting voltage differences. We have a voltage value
on one side, and another one on the other side. Then, as the charges move
through the load, the voltages become equal, and the transfer stops.
Imagine two equal capacitors, charged at the same voltage. No transfer could
happen.
If we use a switch and a transformer of 1:1000 ratio (for example), we could
charge  up  one   of  the  capacitors  at  a  different   voltage  level  from   the  other
capacitor. The transformer and the switch will waste only a little work. So we
can get voltage difference without wasting energy, just by changing a dynamic
V-I ratio, keeping the same energy.
With the switch-transformer circuit, the voltage of one capacitor will decrease,
and the voltage of the other will increase. The energy involved will remain the
same, but will transfer from one to the other capacitor. Energy will not change
on the system, but finally the potential will change.
The transformer is like a “free water pump” because changes the V-I ratios on
the capacitors. It doesn’t increase energy, but changes the place where the
energy is stored, and the final potentials.  Now, as we have created a voltage difference between the capacitors, we can
power a load by “discharging” the difference on potential levels on capacitors
and finally get the initial voltage difference again.
So the transformer  creates a voltage difference for free (keeping the same
energy on the system), and the load depletes this voltage difference getting
power. The step-up stage on the transformer is a “free” potential change, we
have to do almost no work to get the new voltage levels.
Circuit:
That is the basic idea of the circuit below:
Parameters:
Transformer: K = 1, L1 = 8900 turns, L2 = 1000 turns.
Capacitor C2: C = 33uF, IC = 12V.
Capacitor C1: C = 33uF, IC =0V.
R load: from 9000 to 900000 Ohm.
The idea is to achieve an oscillation, and then, by using the idea of the
transformer free V-I change. The transformer stage changes the potentials on
capacitors, and the load stage is powered trying to equalyze the capacitor
voltage levels.Interesting results:
The values of the Ls and Cs are intended to get 50 Hertz signals.
Firstly, the current on the load gets a high value, then goes decreasing:
But it does not decrease to zero. A little oscillation is maintained:For 9000 Ohm, the voltage is:
Some interesting things about this circuit:
-    The load value is important. The circuit seems not to work to lower
values of ressistance. Then i worked with 9000 Ohm to 90000 Ohm
values.
-    Once started, the current on the load have always a peak value of
200mA. It doesn't matter if the load is 9000 or 900000 Ohms, the current
peak is about 200mA. So it seems the current value on the load
depends on the rest of the circuit parameters.
-    Also, the current is independent of the initial peak on C2. Using a
higher value, we can extend in time. We can get energy on the load for
3 hours with an initial peak of 220 V on the capacitor C2.
Another interesting thing is that more energy is extracted as the load
grows up. For example:
R load = 9000 Ohm, V = 1800V, I = 200mA, 360 W for 1800 seconds.
R load = 900000 Ohm, V = 200000, I = 190mA, 38KW.
Example:
You could charge C2 to 12 V from a car battery, and power nine series
connected 60W light bulbs with AC power for half an hour!.
Conclusion:
I think the energy extracted has nothing to do with the initial energy stored on
the capacitor.I think a dynamic V-I changing proccess is involved, and allows us to extract
energy, only by “voltage equalizyng” on load part. The “voltage de-equalizyng”
part on transformer takes no energy, and is for free.
Energy stored on capacitors does not increase, but voltage changes, the energy
stored re-orders on another voltage conditions, and the new voltage values
depletion is the power on the load.
To me it’s as if we could rise a stone on gravitational field for free, then let the
stone fall on normal conditions. The transformer part is the “free-riser”, and the
load is the “potential-to-kinetic” part.
Goat
@ e2matrix
Thanks for the heads up.
I found the article you posted on scribd  at http://www.scribd.com/doc/8959124/Free-Energy-AC-Generator and the same information and scope shots were there.
I did a search on the transformer model number k3019pl_3c8 and the top hits were experiments in spice... Seems as if it's a spice emulation and should work according to the program so the worst you could do is replicate it and see if it works!
There's a couple of unknowns on the diagram and the description though:
1. Doesn't indicate which side of the transformer is the primary or L1.
2. Mentions charging C2 so is that the input for L1?
3. What kind of Caps are C1 and C2? There are many different types.
There are other items but it seems like it would be easy enough to try it as long as the components can be found.
Regards,
Paul
SchubertReijiMaigo
Hmm, a resonant trafo, look like Rotoverter/Transverter stuff I have read the whole PDF like "Combine.pdf" etc,etc. They use a so called diode pluge to extract power without reflecting back... I search another way to use the 3 Phase PrimeMover Star connection system and use it in 3 Phase trafo in solid state mode...
Another way, in your schematic, I fear when you put a load you detune the system, and you must under magnetize the trafo, (to enable resonance build up voltage/intensity) if your trafo is 480V feed it with only 120 volt (or raise the frequency)...
I have searched about RV or TV specialist to share and discut my diagram and idea, I have found a certain "Ashtweth" but it seems he is not online anymore :-[ ...
conradelektro
@e2matrix:
Since some time I experiment with picking up electricity from the omnipresent RF-smog, specially in the 50 Hz range (from the 220 Volt power grid) and in the 0.1 GHz to 10 GHz range from FM-Radio-stations, mobile Phone towers and the WLAN-points.
The circuit you propose will pick up energy from the 220 Volt 50 Hz power grid (in Europe, if I remember correctly, the US has 110 Volt 45 Hz). The trick is careful tuning into resonance and a good ground connection.
In the 50 Hz range, many diodes will work, but in the GHz range one has to find really fast diodes. Eventually you need at least one diode to drive a DC load like a LED or a little pulse motor.
My experiments did not give good results, so I do not want to talk about it now. It would only confuses the issue (because I am still very confused and do not really know anything useful, just hints and speculation).
But I can tell you, specially the 220 Volt 50 Hz grid floods your building with energy that can be picked up to drive little loads with up to 10 Milli-Watt. And if you are near a WLAN or cellular phone tower, the energy is also comparatively high with a possible useful output around some Milli-Watt.
I speculate that many over unity experiments which show a little over unity pick up power from the omnipresent RF-smog. The energy in that RF-smog is higher than one would think in the first place. And many oscillating circuits pick it up specially when they have a good ground connection. Sometimes touching a circuit provides enough ground to see the effect. Touching also tunes the circuit sometimes into resonance (do not ask me why).
Greetings, Conrad
teslaalset
The numbers from the article are based on Spice simulation with K=1 (couple factor of the transformer).
In practice this will never occur according old school theory. There are always core losses to include, so K<1, which will cause dying out of all signals.
If core losses could be compensated by an external energy source, this could work of course.
