Centrifugal Force Overunity
Started by Overunityguide, March 13, 2011, 04:00:43 PM
Overunityguide
Quote from: iflewmyown on March 13, 2011, 09:25:58 PM
Hello,
This is the operating principle of the Hummingbird Generator designed by a man named Martin I think. He got the idea from a notebook of Tesla's who had studied the effects of the moon orbiting the earth and keeping the same face towards the earth. Thank you for the excellent presentation.
Garry
Thanks for calling my presentation excellent... And maybe the rotation of the plannets has some relation to the centrifugal force overunity effect, but for now I like to concentrate me on my simulated centrifugal force overunity effects before trying to explain how the universe works.
But thanks again for your positive feedback.
Overunityguide
Quote from: SantMat on March 14, 2011, 04:00:32 PM
I watched your great presentations, and have thought much about them. There is a singular problem that I noticed though...
I see that you are modeling the 2 generators as reversed motors to test for how much power could be taken off those 2 generators, compared to the input into the central motor. From this you are seeing a 40:1 ratio of output to input...
The problem that even I overlooked in the beginning though is that the rotor and the stators of the 2 generators to NOT move in relation to each other. So, in reality, your modeling is actually showing how much power it would take to move the weighted arms from their extended positions, not showing how much power output that there would be on those 2 generators. So, your sim in actuality is merely showing at what power level you'd need to impart to the 2 generators(motors) to get the weighted arms to even move from their extended positions. I am sorry to bring this to your attention, but I felt I should say something. Had the rotors and stators of those 2 generators been moving in relation to each other, then this would certain merit overunity.
--- This is observation is correct ---
... the rotor and the stators of the 2 generators to NOT move in relation to each other.
--- This is incorrect, if you look closely to my first simple centrifugal force COP 1 to 12 overunity example video:
http://www.youtube.com/watch?v=er1VRPfK5Sw
You will be able to see that the swinging weight is not connected directly to the flywheel, but instead it is connected to a connecting rod which is in return connected to the flywheel. So the rotor in this simulation is mounted to the swinging weight and the stator is mounted to the connecting rod (so not to the flywheel), This is the key principle of my simulation. So the centrifugal force is rotating the swinging weight which turns the outher motor connected to the connecting rod. So it is rotating. And in my second video:
http://www.youtube.com/watch?v=WcpF-n3Dd8I&feature=mfu_in_order&list=UL
This connecting rod is replaced by a set of gears, connected to the fixed center gear. So in this example the gears at the rim keep standing nose up and the swinging weights are turning. So here you see also that both stator / rotor combinations are turning.
For seeing things closer, please download the simulation files so that you can zoom in while everything is rotating.
Thanks for your reply and with Kind Regards, JdR
e2matrix
Very nice work on the sim.  Looks like it would be good to start building.  It somewhat reminds me of this device which according to the inventor will be in production very soon: http://peswiki.com/index.php/Directory:Alpha_Omega_Galaxy_Freefall_Generator_(AOGFG)
Poit
Quote from: e2matrix on March 14, 2011, 05:39:37 PM
lol... thats one thing ive noticed in the OU community.. every thing is "very soon" and "just around the corner" ... that 'corner' must be 100,000 miles wide lol...
@author of this thread.......the sim looks very impressive, I might give it a go my self (actual build that is)... like your explanation of it all, very clear and articulated.
freeenergy4all
Quote from: Overunityguide on March 13, 2011, 06:59:38 PM
Thanks for your input, and your both statements about centripetal force are totally correct. Your work also looks interesting, and if you have some extra spare time left, you can also build my plans if you like... Kind Regards JdR
Thank you for your blessing.  If I get some time, I will definitely  build that machine.  It looks very straightforward to build.
God bless,
       Ian
