the_big_m_in_ok
Quote from: JouleSeeker on July 27, 2011, 02:06:20 AM
... 1. Are there any replications? Anyone? ...
2. Can anyone translate the German on the sketch? ...
Answer to #1:
There are U.S. Patents that anyone can look at, and they fall into the general catagory of "magnetic amplifiers", which can use transformers that look somewhat like the drawing.  It's merely a question of searching the Patent database.
Answer to #2:
If I could try and accurately read the German handwritten cursive, there should be several free Internet translators avsilable, but their library of electronic technical terms may be small.
(I looked at the drawing again.  I can't separate letters into any distinct word(s) by his handwriting.  So, someone fluent in German can try?)
--Lee
manfred
I've been following this interesting thread for some months... Two questions, please:
1.  Does anyone know where Feynman is -- the fellow who started this thread?  I thought he was doing good work, and I hope he is alright.
2.  Has anyone heard of the following device ?   It seems to have some similarities with the Gabriel device.
I've been working on alt-energy for years, and in particular, the device below has caught my attention because of its simplicity and because of REAL TESTS demonstrated -- NOTES IN GERMAN -- NEED TRANSLATING HELP!
http://philica.com/display_observation.php?observation_id=61
Demonstration of the device to "1500 people" by H. Schnelzer; sketch of device by J. Horvath; acquired from Horvath; article in Philica by C. Turtur.
I quote from the article below, and I will attach the drawing from the written-PDF for convenience.
3. " It is said, that the device has been inspected and certified by TÜV-München, by measuring input- and output power and temperature." -- is there any record of these tests?  Can anyone help locate these tests and their results?
Quote from: oscar on July 27, 2011, 11:04:29 AM
text of Horvath sketch:
left side:
Weichmagnet = soft magnet
Hartmagnet = hard magnet
Wirkungsgrad < 1 = cop < 1
A1 u. A2 sind durch den Luftstpalt bestimmt = A1 and A2 are defined by size of air gap
vx ist die Magnetisierungsgeschwindigkeit = vx is the speed of magnetization
right side:
Parameters to alter
N1,2= Number of windings
P1= primary power
P2= secondary power
U1= input voltage
U2= output voltage
d= air gap
Ø1= flux1
Ø2= flux2
A1= virtual magnetic cross section of Ø1
A2= virtual magnetic cross section of Ø2
vx= magnetization speed
ratio A1/A2 ... magnetic resonator
epsilon = ratio t1/t2
f = 1/t2
I1 = primary current
I2 = secondary current
PS: yes, a car accumulator is a car battery ('accumulator' as it accumulates charge)
Mavendex
I have decided to apply a modified GNU license to the application, which should protect the device and the mods that get out there, yes we won't get rich but at the same time I think we need to not worry about money at this point.
Money Comes and goes, but time is something you can never get back and is the most valuable resources any one has.
High amps low volts just like the above mentioned patent will serve you well, I've been slowly saving my piggy bank to have a new shell made out of Permalloy which will be much easier to magnetize than the mild steel, it should also separate those magnetic fields even better.
So mod away and break the chains that bind us.
Mav
e2matrix
Quote from: Mavendex on July 27, 2011, 03:15:10 PM
Mav
Thanks Mav for the update and good news.  Please let us know of your successes.  And you are right about needing something other than money -  this entire world economy may soon self destruct which will leave many without power if we don't have some sanity among politicians OR some OU devices.
JouleSeeker
  Thanks, Lee, Manfred and others.
There is another thread just for this "magnetic amplifier" by Horvath et al., here for those interested:
http://www.overunity.com/index.php?topic=11256.new#new
(This is where Oscar kindly posted his translation of the German.)
  Sorry to interrupt the flow.  My sincere best wishes for success on the Gabriel device!
PS -- I agree with e2matrix --
QuoteThanks Mav for the update and good news.  Please let us know of your successes.  And you are right about needing something other than money -  this entire world economy may soon self destruct which will leave many without power if we don't have some sanity among politicians OR some OU devices.
