SchubertReijiMaigo
Thanks for pics, this design look promising also, another Thane variant !!! I will save those pics for further experiment and backup data, after Tesla/Gabriel device experiment...
@ Jack: the input power is on the center leg right ? And you use high perm for the secondary circuit or the same for both ?
Jack Noskills
Thanks broli, that is much better picture.
Magnetec has oval shape cores, by connecting two ovals in the middle, then a suitable nano/magneperm core on top of that (or both sides) would be equivalent to this. A hamburger.
Only difference to my crude prototype would be that those ovals would not touch each other in the middle because of protective casing. This might make things different, but theres always a grinder if cores must touch. If I had 200-300 Eur to spare I would certainly try this out, multistrand square Litz wire to ease winding, maybe 5*5, connecting individual strands to get only one strand active...
Jack Noskills
Schubert, input is the center leg. My prototype was iron so I would quess that works even if permeability is the same for both cores. But my bet is that higher permeability second core would be much better.
penno64
Hi Jack,
I have been waiting so long to have a go at this one.
Having read and read then re-read again your post, if I understand correctly, the three primary
coils are from identical transformers.
In Broli's 3D, he shows the centre coil mounted sideways. Would this be correct?
I have a good feeling about this and can't help but see a link to LOCKRIDGE.
I have several MOTs that I have taken the coils out from and kept the laminations. Will attemp
to put this together.
Kindest Regards, Penno
Quote from: penno64 on August 08, 2011, 07:44:15 AM
If you're talking about the crappy paint illustration I made then no that's not correct, I just made it to demonstrate a point, and I also just removed it to prevent further confusion. The 3d rendition is the correct one.
