Quote from: Mavendex on August 20, 2011, 07:50:42 AM
but I figured out a way to doit without the permalloy.
Please elaborate.
Hope
Maybe a copper wire primary twisted together with a iron wire secondary?  OR one of these babies:
http://www.rencousa.com/RL-1324.pdf
in a double capped pipe wrapped in a easy to saturate wire coil.   This link has some pretty awesome amp capacities inductors.
Hope
I meant Walter Russell not William Russell
If we place RF withing the Rodin coil can we not then use a small florescent tube to follow the output vortex line of the Rodin coil and build a collector to match it?
Mavendex
Quote from: Hope on August 21, 2011, 09:14:30 AM
Again you need a ton of flux and the rodin coil has a beefed up B-field but no H, H = density, B= Strength, You can get your H from ferromagnetics, and that galvanized steel pipe is basically worthless probably would be better with Iron or a Permalloy rod or even a non galvanized steel rod something soft.
Now theres a trick to making the rodin coil work better, if you analyze the rodin coil you will notice you have 9 turns of 1 circuit and 9 turns of another, going around and thru making the little hole that focues the flux of said coil. if you notice there is 2 turns on the rodin coil that are directly next to each other that are opposite charge flow. thats the power right there that opposite charge flow of the rodin coil increases its power a ton.
Now how do you capitalize on that, "twisted Pair" but in lies another trick, if you lay 1 twisted pair next to another twisted pair you get diminishing returns and some cancellation because of the timing in the coil, so how do you get a bunch of turns on the coil to get the desired output? Every time you go around shift over 10 degrees, your inner hole will get tiny but you can stretch out the center and tape it back, and eventually after enough turns you can get enough juice to make some serious amperage. its just a real pain in the yang to build and takes a ton of time.
Just a few tricks you can try but most definitely something that juicy will levitate a 16 gram magnet with no problems the more you can squeeze on the more weight you can levitate. Or sling across a room at high velocity if you use a nice capacitor bank!
Mav
