Lenz's law can be violated.
Started by EMdevices, April 09, 2011, 08:19:16 PM
EMdevices
I posted this at www.overunityresearch.com,  but it doesn't hurt if it gets some exposure here as well.
I derived some conditions for which Lenz's law does not hold in ferromagnetic materials, at the macroscopic level.  Take a look at the attached document and see if you spot any mistakes or omissions.   The implications are huge!
EM
EMdevices
The simplest device can be just a biased ferrite rod or toroid that will self oscillate if biased correctly on the negative slope of the instantaneous permeability curve.  This is similar to negative resistance circuits and Gunn diodes for generating microwaves.
EM
e2matrix
Nice find EMDevices!  I assume you have built something that showed this effect?  If so was it as simple as the diagram you have here?  Can you give additional details on a sample circuit?   I always like the sound of 'negative resistance circuits'  :)
Bruce_TPU
Hi EM,
Very good to see you my friend!
Another idea I have found, to "work around" Lenz's law, is a cog free PM generator. Two secrets to make it work...
1.  Number of coils divided by number of magnets must be 1.5, 2.5, 3.5, 4.5, etc to work.  Example:  If I have 24 coils, with 16 magnets, I take 24/16=1.5  No cog!
2.  Each coil is to be seperated out individually, rectified and then the outputs combined.
And that's it.. It is already Patent pending, but not by me.  Very cool stuff!  It really works.
Kind regards,
Bruce
MrPayback
Hi Em_devices,
If I understand correctly, the battery is actually a pulsed or sine input? The cap keeps the core saturated so there is no lentz force reaction. The cap and inductor are just parallel LC resonance. Does that sound about right or did I miss something?.
I am playing with that idea right now based on a ferro-magnetic OU device disclosed by Hector. What is interesting is there and what I am working on is there may be an opportunity for symmetry breaking when an earth ground is used similar to Kapanadze and SR193 devices.
