mondrasek
Quote from: webby1 on August 19, 2012, 12:46:19 AM
WHAT do you want me to talk about M.
Anything and everything you observe, measure, notice, etc., while poking your TBZED.
When you want to.
Sorry if I interupted any testing!
M.
mondrasek
Just saw this on a table upstairs and could not resist.
I hope everyone is having a wonderful weekend.
M.
Grandma!! We've found you!! Please write, we miss you.
--Tinsel
@neptune:
Thanks, and you are right. I don't mind tough and realistic challenges to my skeptical position and work; constructive criticism and real refutations of what I might say or believe or do are fully welcome and I +especially+ need others to check my maths... can you imagine working a calculator with claws like that?
You will eventually encounter my very own personal troll though, who manages to sully just about every thread I post in, yet is never able actually to refute anything with checkable facts, outside references or his own demonstrations.
I only lack one thing to be able to put my full skillset and resources onto this issue, and anyone who knows me will confirm that I do NOT need to be convinced of the reality of anything before I start building and investigating on my own. In fact, like Inspector Morse, I don't have theories... just questions.
-TK
(And.... like Inspector Gadget, another of my personal heroes ... I might have one or two tricks up my sleeve.)
@Webby, thanks for the description, it sounds like you are having fun.
But.... come on. You have on your table a device which has the potential to overturn hundreds of years of real scientific research and theorising, theories that have so far worked well enough to design sophisticated hydraulic systems and even submarines. But if MrWayne's device, and yours, actually make more work out than in, all that will have to be rethought, especially that fundamental law of thermodynamics that results in Conservation of Energy being taken as gospel all over the world and for many many years. Entire careers of scientists and educators will be rendered null and void, textbooks will have to be rewritten, and more. I don't think that a person who is not trained in the "hard" sciences like physics or engineering mechanics can fully realize what a truly revolutionary thing this is if it actually works.
So... it's pretty important, I think, to get good reliable and repeatable measurements from a known configuration of the apparatus, with good recordkeeping and so on. Any measurements must be as accurate and precise as the setup and our experience allows in order to know that we aren't fooling ourselves and so that this revolutionary system will be believed by others.
I wish I could tell you how to improve things to make them easier to measure. The very first thing I'd recommend is a good digital scale in the weight range you need. Even if it only measures accurately to a gram of precision, that will be better than what you are using. The scale I used in the "virtual water inverted TE" video cost about 20 bucks from Harbor Freight and is accurate to the gram, and I've got a mechanical Harvard trip balance with a calibrated precision weight set for comparison, so I do know the accuracy and precision of that cheapo scale are usable for this purpose. (The OHaus Harvard Trip Balance has a capacity of about 2 kilos and can weigh reliably down to the tens of milligrams if I hold my breath and use tweezers for the tiny weights. I found it at a Goodwill store, along with the precision weight set.... for twenty dollars. ) Next you might try the Dollar Stores looking for transparent plastic rulers with cm and mm scales in the school supplies section.
Thanks for doing the hard work and for your willingness to put yourself out there and sharing.
--TK
(Eta: a tenth of a pound is 45.4 grams, so a scale that's precise to the tenth of a pound still leaves a lot of room for error.)
