W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
Bruce_TPU
Quote from: am1ll3r on April 28, 2011, 04:35:41 PM
Hi Everyone,
Using Phun I put this test video together. Proportion and timing are all off but I think this is the basic idea.
http://www.youtube.com/watch?v=7R-ypRlo8TY
Cheers,
Chris
Hi Chris,
You have it on wheels not rollers.  Do you have the lever 1" in FRONT of the fulcrum?  Also try a sim, with rollers, having the lever 1" above the fulcrum.
Cheers,
Bruce
nightlife
Bruce, the rollors you are talking about add even more resistance. Wheels work better. As for a lever like you are talking about. That will just add more resistance. You need to keep it as simple as possible to get the best effect.  I was up till 3am playing with it.
One thing I found about this concept is that it is like Veljko Milkovic's pendulum pump.
Bruce_TPU
Quote from: nightlife on April 28, 2011, 05:45:32 PM
Hi Nightlife,
It is not my design, I am just stating how the man said he had it working.  He said rollers, he said lever.  Of course anyone may modify anything they want, because their way is better.  But, IF his really works, might be a shame to have not played with it his way....
I kind of like the idea of a rocking chair bottom for the base, of course no idea if that would do anything...lol  Gravity machines are NOT my forte'...lol
I only became involved, hoping that Bill had a machine that worked and was really going to open source.
Cheers,
Bruce
nightlife
 Bruce, I know it's not your design but I don't understand the lever. I thought he was talking about the arm the weight is attached to. The same with the rollers. I thought he was referring to rollers as wheels and wheels would provide less resistance and this concept must have as less resistance as it can to get the best results.
nightlife
 At this point, it is obvious that he doesn't have a working unit now or ever. He said he built one 2 years ago but has yet to show us even a picture. He doesn't have one that works as he said because he can't. It is impossible to have a working unit based on his concept.
