Wireless power transmission using Joule Thief
Started by Positron360, May 04, 2011, 08:57:36 AM
synchro1
Here's an important video from epowerplus from two years ago:
http://www.youtube.com/watch?v=u1HvZmyQ95g&feature=plcp
Here's the same question from TinselKoala from ths "youtube" video followed by epowerplus's response.
"I am curious about the requirement for the bifilar winding. Are you connecting these coils as "hairpin" or true Tesla bifilar windings"?
epowerplus's response:
"Connect the beginning of one pair to the end of the second pair....which leaves you with two wires left over, one beginning and one end"...
This question is really banal, because only what TK is calling the "true bifilar" is any good for broadcasting and receiving power anyway.
synchro1
Epowerplus maintains that the addition of his very tiny capacitors improves transmission efficiency by a factor of ten. Sohei reporeted that the addition of a capacitor made no difference. Sohei would need two capacitors on his setup to acheive resonance, one of identical value on both the receiver and primary broadcast JT coil. It's also possible that the inclusion of these capacitors may polarize the oscillation and kill the free power effect. Easy enough to test for.
Another outstanding difference in the comparisons between these two simple circuits is the absence of a full wave bridge rectifier in Sohei's version. These non inclusions may be important in replicating Sohei's effects. Again, easy enough to test for. There's a strong chance that the rectifier may kill the dipole in the receiving coil. I don't know if there would be any long term damaging effects to the LED'S running them off low ripple A.C. as Sohei's doing. It looks like it works fine, although it may shorten the LED life span. It still may pay in power savings in the final cost comparison over time even if it does. The other interesting fact is that Sohei reports that it makes no difference which side of the receiver coil the anode or cathode of the LED'S are attached to. The inclusion of the rectifier would certainly annul this effect completely.
Epowerplus does not turn his receiving coil around. I tried that once with a pancake and spiral wireless broadcast JT setup and noticed the LED grow brighter. What I didn't realize was that the increased brightness may have been accompanied by a decrease in input power to the broadcast primary! What a startling revelation from Sohei Thoth! I can't wait to try it. I wonder how many LED'S  it might be possible to run in series by simply turning the receiver JT around in the other direction? That measurement really astonished me! I wonder what causes it to behave that way? The broadcast power equation may apply to that effect. The power of a tiny spark is infinite. It can be detected omni directionally from any where in the universe, sending a shock wave through the fabric of the Space Time contiuum. Is it possible Sohei has shown us the key to unlocking infinite broadcast power? We can't afford to let his result fall by the wayside merely because Sohei's experiment lacks the kind of cumbersome complexity some of our "SHOW OFF" contributors offer us.
synchro1
              Jonnydavro shows us a "Joule Ringer" circuit with a 20K pot and 6 volt buzzer driving the base of a 3055 transister. The pot and buzzer act as a fiendishly simple pulse width modulator. Connected to an air core Tesla bifilar transmitter coil like Sohei's, one should be able to tune for peak coil resonance very easily. The experiment I envision would include a 12 to 200 volt transformer turned around and capable of lighting 120 volt LEDS, so the wireless receiver coil should light a 120 volt LED bulb to full brightness without causing a problem. The buzzer "pulse width controller" can  bring the tiny pico farad capacitor tuned broadcast and receiver bifilars into peak resonance with the 20K potentiometer. Now, the question is: Will it be possible to string 120 volt LED'S in series with the receiver coil reversed counter wound facing the primary broadcast coil  with no effect on input the way Sohei shows his 3 volt LED'S bulbs behaving?
               Replicating Sohei's effect on this scale would allow us to self loop off solar feedback, and run the remainder of the 120 volt LED'S at full brightness free of charge, without cumbersome complexity. The Lights of America bulb in the picture has been tested to gain in series. Other types have current inhibiting circuitry that would cause them to fail to work this way.
               Here's a video of Imhoteb lighting a 120 volt LED with "ZERO AMP" draw off, not wireless, but ground oscillation! It should be possible to wire an endless number of this type of 120 volt LED in series between the positive battery pole and the negative to a neutral Earth Ground, like Imhoteb, and still maintain zero amp draw. In this case the Earth Ground is the pipe in his bathtub. The natural oscillating frequency of magnatisem is 1.59 Khz. This must the frequency between the Earth Ground and the positive battery pole as well as between the counter wound opposing bifilar fields that's exciting the crystal LEDS in  the zero amp draw wireless setup.
http://www.youtube.com/watch?v=QR7dEJtP79A&feature=em-subs_digest
synchro1
"I took a 12 Volt battery and connected its positive terminal to one end of an LED bulb with enough series protection resistor. Then I connected the other end of the LED bulb to earth (soil with moisture outside my house). I did not connect the negative terminal of the battery to anything. I expected the bulb to glow, but it did not glow until I connected the negative terminal of the battery to the ground as well." This is apparently how Imtotob completes his circuit as stated by him in :18 seconds of his video. He registors zero amp draw! It's important to note that you can't use the same point for the battery Earth Ground! You need two different Earth Grounds! This completes the circuit. The voltage differential between the grounds generates the transverse oscillation in the standing wave!
Here's a great video by Bill Nye on the electrical circuit:
http://www.youtube.com/watch?v=rg-XFXdtZnQ
