Overbalancing wheel
Started by SPANG, May 10, 2011, 12:46:30 AM
Low-Q
Quote from: SPANG on May 19, 2011, 07:51:05 PM
Vidar,
       The long-standing argument I have with you, is simple; you say, that ANY overbalancing device,
cannot work if it does not contain POTENTIAL ENERGY.  As you know, I beg to differ!
If anyone else is of that thinking, then I feel sorry for you ,as you are limiting yourselves to other ways of
doing things ----- they may be unconventional ----- but so is perpetual motion!
From now on, maybe you Vidar, should be known as CAPTAIN POTENTIAL (?)
'Tis a shame, Vidar, to see a man of your obvious ability, to waste your time on obviously stupid ideas,
that end up with you 'going down the tubes'.
SPANG.         (BILL.)
The problem is this: What APPEARS to overbalance, does in reality not overbalance. It just looks like it. You have torque and time factors which will counterbalance the whole system. One cannot "see" time and torque in a drawing, but you can only see what appears to be overbalance - and by that conclude that the design will work. One must base the truth on all the facts, not just parst of it.
But, we will never agreed in this anyways. I suggest you start building this machine. I would be the happiest man in the world if I'm wrong :)
Vidar
Dr
Vidar: you should open up your mind, as they say there is none so blind as he who will not see!!! FACT there is no math formula that states that a gravity only wheel is impossible. If you took all the experiments that have been done to date, we would have barely scratched the surface , of how to get a gravity wheel to work!! Have you read about Bessler? I have , and its what changed my mind about gravity only wheels, before I was a BIG sceptic like you! Go Bill!!!
SPANG
Thanks  'Doc'.
I needed that.
SPANG.         (BILL.)
onthecuttingedge2005
there has never been a working system that works on one energy source alone, it requires multiple energy sources to get it to work, even an electric motor requires multiple types of energy formula in conjunction to function correctly.
using gravity alone is not going to happen. you need a circle of energy sources that relate to each other to make the other do work.
this is what I call the slave driver philosophy, if there is no one to make the slave do work then the slave will do no work!
same as gravity.
Jerry 8)
SPANG
Jerry,
       I suggest you join a knitting club --------- knit one, pearl two, drop three, pick up four!
