Muller Dynamo for experimentalists
Started by plengo, May 12, 2011, 01:04:21 AM
0 Members and 104 Guests are viewing this topic.
gyulasun
Quote from: erikbuch on May 13, 2011, 08:19:09 AM
Great work Fausto!
Do you have the dimensions on the bobbins you ordered?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220690920914&ssPageName=ADME:L:OU:US:1123
It didnt say any measurement on ebay.
Best regards
Erik
Erik,
In this link
http://www.gonesewing.com/servlet/Detail?no=122
two measures turn out: Bobbin diameter measures 7/16" thick x 13/16" wide.
Gyula
erikbuch
Tudi
don't kill the scpetics :(
- magnetic field without usage just makes other objects inherit their matnetic spin orientation ( get magnetized )
- inserting a metalic object into a magnetic field will make it change
- removing the metalic object will make it regain it's original state
- you invested energy to move closer the object and to remove the object. At this point only you made all the action.
now try to imagine :
- i move a wire in a magnetic field
- wire will have "current" in it
- i use this current on a bit further in a motor and convert it back to mechanical motion
i want to break the chain by making the motor run. I can run the motor as long as i'm sacrificing mechanical energy to move the wire closer to the magnets. I can deactivate the motor when the wire is at closest position to the magnet. This is all fine. What next ?
What i really would loved to see, romero having a lightbulb attached to the device as consumer. And make it run more then 5 hours. Yes i know, someone already explained to me that there was clear evidance this lightbulb was not needed. Still, it would have been a simple example to make most of us get very very excited.
Spent 2 days trying to figure out where the energy comes from. I completly agree with the balance part. I agree that the device can loop for days/weeks. I cannot figure out how it gets OU :(.
Someone said that the coils should get cold after a while, that is my best guess so far :(
Edit: Actually if one of the magnets is pulling all the time towards a coil, and none are in "pulling back mode" = the coil circuit is broken fizically, then in theory it should try to go forward all the time. No ?
