Muller Dynamo for experimentalists
Started by plengo, May 12, 2011, 01:04:21 AM
EMdevices
Thank you guys.   I'm glad you appreciate what I'm posting.
Here's an updated graphic.
I shifted the Flux curve up, so it starts at zero.  When I normalized the curve for my previous chart, I had overlooked a code line in my script.
Anyway, speaking about integration, it has to start with some intial value, which we don't realy know, but do have a clue as where to start.   The clue is that when the induced voltage is at a maximum, the flux is at a minimum, and so I chose zero as my starting point.   So now in this new graph, we can see that flux in the positive direction is slightly higher in magnitude than the negative peak, which also makes sense because we know the S-pole is attracting to the biasing magnet's N-pole and the combined B field is higher due to the attraction.  So this is just one more confirmation that we are interpreting this correctly.
A comment on the voltage waveform:  we do not have this same position ambiguity, of where to shift the curve up or down, because the top and bottom flat peaks tell us the FWBR is conducting and we are seeing the capacitor voltage, so we just center the waveform based on the top and bottom peaks, which is what I've done.
This weekend I'm working on my dynamo, winding coils!  Next weekend I might do more calculations.
EM
PS,  Nice build ChrisC, looks like you posted while I was typing my post.    Yes the waveform is looking pretty good, and if you clip those peaks at 12 volts perhaps, than it might look very similar to RomeroUK's waveform.
chrisC
Quote from: bolt on June 09, 2011, 05:07:41 PM
see this it will help!
http://www.overunity.com/index.php?topic=3842.msg290354#msg290354
Hi Bolt:
That suggestion is very meaningful. I will find time after this weekend to play around with the inductance tuning and let you know next week. Thanks!
cheers
chrisC
nul-points
hi all
user 4Tesla was just asking in the MD thread about which stator mag & washer config people were using and this reminded me that there was another interesting outcome of my coil test
apologies, this slipped my mind after i mentioned about Romero's gen coils possibly being connected in opposition - after that, all hell seemed to break loose and i forgot to mention the following!
my coil test used scheme 'C' - core fully up to washer & mag
however, i observed that the presence of the washer DOUBLED my pk-pk output - on-load with a 10 ohm resistor!
all other details as for my earlier post around when i questioned Romero's gen coil connection
my washer was 2x20mm OD mild steel, countersunk centre hole, approx 6mm ID
trace for waveform & test photo (both WITHOUT washer) below
thought this might be helpful info
np
http://docsfreelunch.blogspot.com
i_ron
Just when you thought it was safe to go in the water...lol
http://www.youtube.com/watch?v=hkV2Y4Yke4I
Now can someone explain this to me?
Ron
