PhysicsProf Steven E. Jones circuit shows 8x overunity ?
Started by JouleSeeker, May 19, 2011, 11:21:55 PM
nul-points
Steven
i wanted to thank you for raising our interest in your oscillator circuit and its associated investigations
i have to admit, when i saw your thread start i didn't follow it up at first because i thought the subject would have been exhausted in the various JT threads already in existence (not that i have anything against them!)
however, i'm hooked!
even in this seemingly simple circuit, all sorts of basic issues have been raised; it's certainly been a worthy test-vehicle so far - and we've only just got out onto the freeway  :)
what prompted me to write this now, is that i've been doing some of my own experiments since the end of last year, with DIY cells using thin sheet & foils of dissimilar metals & unusual hydrocarbon-rich 'electrolytes'
(as noted at my blog linked below)
i'm attempting to achieve a self-sustaining combination of cell & LED flasher circuit (ie. the system will need to obtain energy from the ambient environment)
i appear to have succeeded with one combination which has maintained an average 2 cell voltage of 1.2V since the beginning of March (all other attempts have discharged the cells within a couple of months)
although my existing LED flasher circuit is very low-powered (approx 1uW), it can only continue flashing the LED down to around 1V supply, which means that i need 2 cells in series as a supply battery
however, as a result of my experiments with low-powered variants of your SJ1 circuit, i have now been able to produce an LED flasher which is operating down to around 0.4V, flash rate approx 1 per 20 seconds - so i can now power an LED flasher load circuit using only 1 cell - and reduce the component count down from 12 parts to 7!
i've altered the base capacitor and diode values to achieve a slow flash, and i've connected a piezo sounder across the base capacitor to generate a 'click' with each flash
i've just run a capacitor-only test with that variant and i was able to generate 42 flashes from a 100uF capacitor charged to 0.8V (taking approx 10 minutes)
using only 0.8V as supply, this circuit can develop a pulse of approx 64V across the supply inductor (whilst on-load to the LED flasher) and it has actually increased the terminal voltage of one of my DIY cells back up to 0.81V, the original o/c voltage i measured when the cell was created
as you can imagine i'm very impressed with this deceptively 'simple' circuit and i look forward to seeing what else we can learn from our investigations
thanks again
np
http://docsfreelunch.blogspot.com
NickZ
  @ Joule Seeker:
   Here is the link that you requested.
   http://www.youtube.com/watch?v=JIIhgHTEoM0&feature=related
   Dr. Stiffler has mentioned that the device can also light two white leds, and not just the one red one shown in the video.  I stumbled upon this video the other day, as it caught my attention.
  He uses an antenna wire and a ground connection, but no transistor, pot, or resistor.  It's different than any other device out there, like most of his projects.  Great find...
xee2
@ nul-points
Getting a silicon transistor to work from 0.4 volts is a good accomplishment. Congratulations.
nul-points
Quote from: xee2 on July 07, 2011, 07:33:20 PM
@ nul-points
thanks, but i think the congrats are due to Steven for bringing this type of oscillator to our attention!  :)
Pirate88179
Quote from: NickZ on July 07, 2011, 07:31:24 PM
  @ Joule Seeker:
Wow!  Dr. Stiffler has done it again.  That is really amazing to me.  It would be very interesting to see if this could be scaled up a bit.
Bill
