Spinning neo sphere inside coil
Started by futuristic, June 03, 2011, 04:49:09 AM
energia9
energia9
i think this neo sphere device with a little config can be hooked back to itself to selfrun.  this thing is very interresting..
retrod
Quote from: energia9 on June 04, 2011, 09:28:34 AM
here is another guy with a degausser coils and a sphere magnet   2 watts in more watts out,
This is the way to go in my opinion. its simplicity is fantastic,  we need to create a device which is self running, then make other models which will create power that is usable by our home devices.
I think you may be talking about a video I made some time back. The energy is there, the Lenz is what needs to be overcome. In that regard the ideas and coil shorting circuits put out by Romerouk, Gyulasun and Konehead look to be the answer. Sorry, no links. The large degaussing coils are easy to work with but offer high resistance. This may not matter as much if the harvested energy can be isolated from the load per Koneheads latest comments on this board.
I found the sphere magnet is too difficult to manage and changed to the rod style with a hole in the center. I was able to then move the magnet around under speed using the tip of a wood pencil. I like simple experiments  :).
Here is a messy photo of one of the last experiments some months back still with the sphere. Two degaussing coils in a vertical plane, reed switch across the top feeding the coil shorting circuit. Two coil shorting circuits worked better then one. I also had good results using the "Stingo" circuit as the coil driver (high speed low current drain).
I am gathering parts for the Romerouk disc device or I would still be working on this.
RD
energia9
Quote from: retrod on June 05, 2011, 11:25:19 AM
RD
hi retrod, nice to see you around here, i would advise you not to stop experimenting with this device,  romerouks device seems promising but all i can see again is a big dead end because his schema was still missing a few parts in my opininon, of course it can be developed, but as far as i could follow there are non who could replicate. back a few years ago i saw a professor who made magnet spheres rotate indefinately.  to develop this device is just way simpler than of a dynamo, i think this can be self runned just the same as romerouk s ordinary dynamo.
regards
energia9
