Simulation of the Muller Dynamo
Started by poynt99, June 25, 2011, 08:59:55 PM
poynt99
Quote from: i_ron on June 28, 2011, 06:37:52 PM
Did a test on the world patent today and it is a good producer... but reflects back to Prime mover
27 1/2 watts out but at a cost of 32 1/2 watts extra on PM
Middle coil...20 + 20mfd
Ron
Good stuff Ron.
Will be interesting to see how it sims out.
.99
Thaelin
   If you are looking for some numbers on what it would do as a
generator then d/l the pdf I have. google esl-ie-84-04-137.pdf and
it should be the first entry. Address is at tamu.repository.
thay
i_ron
Quote from: Thaelin on July 03, 2011, 07:17:08 PM
thay
Thanks Thay,
Have you done any work with this?  I can tell you that a concentric wound bifilar doesn't work. In the tables at the end of the PDF there is a column for "control degrees" is this the offset between the windings do you think?
In the one tiny sketch it shows the 'control winding' in a different slot but here again there is a lack of clarity and detail necessary to replicate.
Ron
Thaelin
Ron:
   None at all. Just read someone ask if it had been used as a gen. Just happen to be reading the file at the time and passed it on.
thay
i_ron
Quote from: Thaelin on July 05, 2011, 12:46:06 PM
Ron:
thay
OK, thanks
Ron
