Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
k4zep
Quote from: madsatbg on August 14, 2011, 12:58:14 PM
Hi Ben,
good job,
but the inner and outer coil should have the same number of turns.
The photo shows inner coil is greater. ???
regards madsatbg
Hi Madsatbg,
IF you are talking about the "CAP", I think we have found your problem with your unit.  WIND 11 METERS of wire on the form, this forms the first coil, then wind 11 meters OVER it, this forms the second coil, one over the other.  THE TOP/OUTER COIL WILL HAVE FEWER TURNS as the diameter is greater.  The length of the wire is important, NOT the number of turns, on the CAP.
My reactor coil and the coil on the plastic form over it has 92 turns on the reactor and 91.5 on the outer coil both wound in the same direction.
Check TT's Videos, he emphasizes this and mentions the different turns number.
Best of luck to you, I hope this fixes it!
Respectfully
Ben K4ZEP
madsatbg
gegyx
Hello
I present to you a pdf of photographs of the construction of a pyramidal structure which I carried out this week.
fichier pdf: Construction pyramide.pdf
k4zep
Quote from: gegyx on August 14, 2011, 07:04:49 PM
Hello
Excellent work!
Respectfully
Ben K4ZEP
zhak
hi all
Ben
video (TPP V12 Tutorial Part 6 of 13.avi) time (14.55)
If you count the turns of the plastic tube, then their number would be 95, it is not 10metrov!
Reactor turns 95
Plastic pipe 95 turns
Where is the truth, video, or PDF?
