Aether and what it is.
Started by jbignes5, July 26, 2011, 03:13:51 PM
jbignes5
 Well you got it.
Yeah the Aether theory explains all the unexplained in our universe. Even to our own planet. Everything suddenly seems completely explainable with this theory in the most simplistic way without complicated invented math equations. It merely says that there is a geometry on the most fundamental levels of our matter and this gives our matter the ability of fractals appearing through out all gross matter for which we have seen.
My theory is not complete as of yet but the basic principles apply to everything after that. We went in the wrong direction when investigating electronics and seemed to think it applied to everything outside of that electrical system, for which it does not. Nature works in a very different concept and one that doesn't need complicated mathematics to explain. Through out all of our history there have been a great many men who have pondered this Aether and I think from all the clues we have available this seems to be the best explanation based on what we can see and what clues those original thinkers observed throughout our history.
Dave45
Quote from: jbignes5 on August 11, 2011, 02:25:44 PM
Well you got it.
I agree, on the shoulders of giants.
jbignes5
 More on the Ormes or Ormus. This is what it is all about.
http://www.youtube.com/watch?v=tHnS3_DZWEU
In the second part at 3:41 there is the picture of what I think this particle looks like. The only real part to the double pyramid are the dots. That is the real matter. The lines are actually lines of force as we put it. These lines are made of much smaller 3 sided pyramids. There was no destruction of the layer. It was a merging of a single conductor layer into another opposite layer. The lines just merged and centered the matter of both layers with both of the layers pointing at each other. It merged the single 3 sided pyramid with another pyramid tip to tip. The matter merely moved aside and fused together as the lines joined.
Curiously this resembles the symbol on the ring of Solomon. They knew even then what this was and what it meant.
This is why the layer repelled open. It allowed a two way conduction to happen and each positive side instantly flew away inside of the black hole. This would be the ultimate fusion of matter. And then there was a way for all conduction to be two way or bi directional. WOW.
jbignes5
Quote from: jbignes5 on August 12, 2011, 11:59:41 AM
What I wanted to point out was merely the structure of this Ormes. I do not recommend the taking of any substance that has been purified. We get this naturally from the water we take in and it takes a lifetime to accumulate in our bodies naturally. Any time you try to accelerate the process you get abnormalities in the results. PLEASE DO NOT TAKE THIS PRODUCT!
This Ormes is just proof of the real structure of the smallest conductors in our Universe. We can learn a lot from this process and then figure out a way to harness it's motion for our own purposes for everything but the personal connection to the "Zero Point". There are a great many warnings that it is dangerous to our DNA to ingest this in concentrated form and even if there a hint that such is so it should be avoided. But we can learn about the ultimate mechanics behind the smallest space of our Universe by observing this Ormes when we add charge rich space to it (heat). If you listen to the chemical analysis he did on this stuff and the resulting observations you can start to see how this stuff works. It seems that through expansion and contraction of this substance that it forms an invisible webbing in the charge laden field. When it cools down or we take the charges away vie an area effect it collapses back into the pile in the same manner because of the attachment of the pan it is in from where it started. This could be a balloon effect filling the spaces in between the charges linking them together and holding to the pan by the link inside of the atoms of the pan. I would assume this is a growth type effect that takes many cycles to form a big enough balloon to make the pan weigh less then it did when started.
This white powdered gold was available in the time of the Egyptians and was probably a left over tech from the people who wanted the Ormes in the first place. From some of the reports I am reading this white subtance is a precipitate of heating cooling cycles on the matter that is in the solution. This separates the conductors trapped in matter leaving the conductors only because the charges have been leeched out of matter through the heating and cooling cycles they provided to the matter.
Just give the whole series of youtube recordings a good listen to and separate the bs from the facts. Facts in this case would be the tests and observations this guy saw about the Ormes.
We need to also think about how this really works. Nature in itself is a set of very complex cycles. Effect one and they all respond eventually. Shield ourselves from the dangerous effect of the Aetheric spin totally and we stop time (Aetheric spin) all together for us, which in my opinion would mess everything up. But if we do it with moderation and merely slow time a bit by shielding a small fraction of the Aetheric spin and we can extend our existence a thousand fold and give us enough time to study the effects on a grander scale. How does changing one little aspect like our atomic spin effect the whole cycle? What feedback will this create?
Some of the texts from that time are suggesting that whoever stopped by and visited did in fact have a hand in our design. We now are thinking on the same level. We are suggesting that we do the same as they did to us. Start life and observe it evolve to better understand ourselves and I think this is the biggest mistake one could do. Because this would make us gods and that is not what we are. We are human and we are unfit to rule as gods. We have messed everything up that we touch. No matter how well our intentions are, we always end up destroying what we touch. This is exactly what they did as well. From the texts of the Sumerians the gods they wanted to do the same. In fact if one of them didn't love his creation so much he would have done the same and destroyed what they created. The creator from the texts was merely a scientist that held all life sacred. So sacred that he defied his own people and set out to make sure we had a chance to survive. This is the Noah story we see in the Bible, Although the names and places changed the original story came from the Sumerian people. This story comes from the Sumerian texts and if the Bible is held to be the truth then the real story from which it came from is the truth also. So all you christians out there need to make a decision. Is the Bible the truth or not. If it is then the origin of the stories in the bible must be the truth then and the Sumerian texts are the original stories from which the Bible was authored.
This is the link for Gilgamesh and the start to your own discovery about The Sumerians and who we are. http://en.wikipedia.org/wiki/Gilgamesh
jbignes5
 Just to give further background to this Aether I have been talking about lets look at someone else's research in that area...
http://home.comcast.net/~onichelson/Thermodynamics2.pdf
And this is the patent that Tesla provided to us to learn from. Notice the generator field coils are on a toroid core.
http://www.teslauniverse.com/nikola-tesla-patents-390,721-dynamo-electric-machine
This was cleverly hidden right in front of our eyes because If the establishment were to know the true aspect of this patent they would have never allowed this patent to complete.
If we are starting to understand what toroids are we know that the magnetic field is locked into the core much like a Pmh of Leedskalnin's fame. If the magnetic field is locked into the core then What is the generator fields working with here???? The only other field we have is the electric field. So that means the Magnetic field is Not how we accomplish generation of currents. In fact when you separate the Magnetic field from the Electric field Strange things happen and even in the case of current generation it enhances the no kick back part of the shorted magnetic field. The only Magnetic field that is present is the one from the rotor of the generator because there is a conversion going on or transformer action through induction of the electric field. Any magnetic field that is present from the exciter is shorted out in the core material and that leaves only the electric field being radiated from each coil winding around the toroid core. Since this field is responsible for aligning the conductor particles in between our matter if forms in lines but of opposite of the magnetic lines or 90 degree angle offset from the magnetic lines. So in the toroid the magnetic field runs around the toroid and is locked in that core. This creates super lines to form cutting the toroid in half. As each line starts from the beginning of the field coils it builds in potential giving  it direction for the super line to follow. This cuts the rotors coils in the same fashion but the lines are better capable of sucking out charges from the thicker copper coils of the rotor. Since a non magnetically shorted coil forms both magnetic and electric field lines the rotor tries to maintain the least amount of difference between the field coils and rotor coils. When you retard the rotor is cuts more wire and auto adjusts the strength of the core by increasing the current in that rotor coil. This process can extract useful work out of nowhere. And if we understand it is merely a sink that creates a vacuum of charges around the process. It is a very beautiful charge pump That uses matters ability to contain or even maintain it's internal charge via it's connection to the environment through the used of the base conductors that are everywhere<-Real charge pump.
I assume this motor should have a fan included to circulate the air which has both a plethora of both conductors and free charges(heat) available to use and extract charges from the rotor coils. Any great conductor can and should be used. Gold being very high on the list but Silver could be used just as well for improved efficiency. I also believe that the higher the frequency of this magnetically deficient current means the higher the density per square inch of wire the smoother the resolution of the density  of the field lines. This should increase the capacity of the Super lines and allow for a greater depletion of charges from the copper, gold  or silver rotor coils would provide. A magnetic line should be the opposite of the electric field line. One being charge full (magnetic) and the other being charge depleted (Electric). With both lines being radiated from a source the magnetic line compensates for the electric and a feed back happens. But what if you could separate the two and keep one busy while the other did it's job and one not effected by the feed back? The environment would have to respond and compensate and Walla we have the perfect process of the perfect heat engine.
Any load should be in between the vacuum and the inlet(antenna) of charges entering the system. From the vacuum to the load and including all the way to the inlet it should be statically shielded to keep the environment from supplying charges before conversion in the load. So in effect you never really complete the vacuum or let it become balanced. This redirecting is the loads job. I suspect the load will not redirect 100% of the charges and we will have a less efficient system unless we offer the best diversion to that process in between the antenna and load. That could include a special transformer of the same variety that he shows in that patent to better separate the two processes. This could be where capacitance or a specific type of there of would be used. This special capacitor was called a condenser.
If we look at a specific type of condenser like an electrolytic  we find a great many things that now make sense. The electrolytic condenser is actually a heat pump, if used in the correct manner for the application.The problem is that most condensers we used today are not properly designed for this usage. They respond electrically to environmental heat. We found this effect best shown with the Captret which was coined by another experimenter. Although the process was looked into by Dr. Stiffler who noticed this effect before the other experimenter. I believe the original observer was Tesla himself but didn't go into it further because of more important discoveries. Although other capacitors show the same effect it is of a lower quality that they get a response from the environment.
This applies top all capacitors except the laden jar. This capacitor when properly used and properly built with the one material I think would complete it (Mana, Ormes) would become the perfect capacitor. It's ability to store straight charges would be enhanced by the Laden jars design. Since I suspect that Ormes is these conductors condensed it would make sense that there would be a better storage medium then air. From the Reports of the discoverer this white power of gold would exhibit the ability to store the charges and transfer them back without loss making it the best storage device for free charges or the lack of free charges in the case of the motor generator. I still have to work that one out but I think there are tons of them in oils too. Pure liquid conductors. Could be bigger then the smallest conductors.
