DIY - Stable Redox Molecules
Started by gravityblock, August 08, 2011, 09:05:31 PM
charly2
Sounds really easy and cheap (as it should be), I don't know how is going to react with the ionic solution and don't have any equipment to test it, but I will try it one of this days just to see what happen.
Days ago I had a similar idea but adding some drops of HCl (PH=1), H and Cl are the same elements contained in the base solution, but never tried, benefical compounds will be destroyed by the chloridric acid?. It is in my to do list.
The dog is still in good shape after some weeks, not any important change since the first week.
I tried the ASEA water for 5 days and rest for 1 week, then I got brave enough to drink from my own batch. I got surprised.
Asea does work, slow but works, I felt some let's say minor improvements on my energy level after the 4th day I started drinking it.
But when I tried my solution the same day I felt the same improvement but really much more energized and focused, I tried for 4 days 2 oz in the morning only, no side effects till now only my battery fully loaded. Now I understand better my brother's dog behavior. :o
citfta
Hi Charly,
The solution you made that you are drinking,  are you making a new batch each day or are you drinking from the same batch for several days?  You mentioned earlier the smell seems to change after a few days.  Is the taste changing also if you are using the same batch?  If your batch seems to be working with no ill effects would it be reasonable to just make a new batch every few days and toss the old one as it starts to change.  It seems like it would be easy enough to make and reasonably cheap too compared to the Asea water.  I also felt a small improvement in my energy level and slept better too when I was taking the Asea water.  It is just too expensive for long term use.
Also are you ready yet to describe the process you are using or do you want to test and refine some more before you share that info.  Thanks for sharing what you have learned.
Carroll
Cloxxki
I relaly want to try Redox water, butt can't afford it right now. Especially not with the risk of it being another great infomercial fantasy.
My health guru thinks it's goose armpit grease fableware.
I'd love to try it for a month or so, as an athlete I am quite in touch with how my body performs.
I've read good stories on drinking peroxide too, full glasses straight up even (accidental occurence, scary...)
What I don't understand is the multiple stages of dilution with the peroxide, does that serve a purpose? Why not mix a couple grams on a liter and be done with it?
Is peroxide safe in these doses? I feel my body (and mind) have great leftover capacity not being used. Something is going to unleash it, but what... I know great things are out there, but as an athlete I use nothing from WADA's doping list. A shame, human groth hormane, apart from being addictive, seems to be great for overall health. Cheating on live.
charly2
When I started to drink it, the solution was 1 week old, not really fresh.
But I have batches 2, 3 and 4 weeks old and the taste is almost identical. The change in taste starts 1 or 2 days after was made until get stabilized (in taste) after 4 or 5 days, I don't know, perhaps that is the way it should be...
The solution in fact is odorless and stays like that all the time, only the taste changes but not much, I gave my wife 2 samples to taste, one and four weeks old and she said they are the same.
Carroll, in case one would like to drink only fresh solution, it is just necessary to make a smaller setup i.e. 1/4 or 1/2 litter just chanching the beaker or glass size and reduce the process time more or less in the same proportion.
I doubt my batches are in the optimum point, but for now it is good enough for me. I'll post some pics later to show how simple is the setup.
citfta
Thanks for the info Charly.  I am looking forward to trying it as I did see some improvement with the Asea water.  Did you decide you did not need to work on keeping the current at an exact value?  Or did you find a constant current power supply to meet your needs?  I will probably make a liter or so at a time as my wife needs to be taking it too.  Thanks again for all your efforts and for being willing to share what you have learned.
Carroll
