Split-force overbalancing wheel
Started by weri812, August 15, 2011, 01:44:54 PM
weri812
To All
this is from Spang
                           SPLIT-FORCE OVERBALANCING-WHEEL
                           _______________________________
In this design, BOTH chains recieve identical downward forces each (10kgs?), 20kgs all told.
The left-hand side of the 'small' bottom-wheel, and the right-hand side of the large bottom-
wheel, are 'pulled' down (by tension), at the same time.
This 'pulling' down, is done by a form of 'block', with roller-bearings, or very small wheels,
attached to  specified sections, of the bottom-wheel, (see drawing).
                           _________________________________________________
Try to see the taut sections of chain, as the weights themselves.
Because the top-wheel recieves 2 equal forces -------------- 1 left, and 1 right, of the top
wheels' hub, and their points of contact are at 2 different distances from the hub, it
overbalances. Continuously ------- forever! The relevant speeds of each chain, are 'catered'
for.
The unbroken lines, of both chains, represent the TAUT sections of chain ------------- and the
broken lines -------- the 'slack' sections of chain!
this is a download link fore a zip file
http://www.multiupload.com/719CGFG5YN
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
SPANG
I'd like to thank Wer, for putting in the above text/drawing.
Please read 'post' #154 under 'overbalancing wheel', as it will help you all, to understand better!
Thanks.
SPANG.                         (BILL.)
P.S.         You have my permission, to build this device, if you so wish!
weri812
Hi All,     copy post 154
       I was thinking, if the device is set up properly, and it doesn't rotate, what would happen if the 'top-wheel'
was given a manual clockwise 'turn' ----------------- would it help?
Thinking along these lines, I wrote to a certain 'someone' ----------- whose name I won't mention right now,
who assured me, that if the device didn't 'lock up' in the first place, it WOULD help, and would carry on
rotating, regardless of the fact, the device never had any 'real' weights to begin with.
I'd like to know YOUR thoughts on this!
SPANG.                              (BILL.)
